Question about HP Laserjet M2727nf Multifunction Printer
Error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
We have on the same day experienced both error 79 and error 49 on this laserjet printer that is only two months old. these errors occurred on fax receive function around our need to power off/on several times throughout the day as our printer's main problem appears to go to sleep and can't wake up and we have to power off/on to wake up the printer
  • lawndale Jul 02, 2009
    We have done the off/on process and that temporarily clears up the problem. Remember the MAIN problem is need to hit the powerswitch off/on after the printer has gone to sleep and doesn't wake up when we touch any button on the printer or when a fax call attempts to come in. Having to power off/on to wake up the printer through a new initialization all the time obviously can't be the permanent solution. I note that on the hp support pages, this never wakes from sleep problem is not limited to us but is occurring for many. HP doesn't seem to yet have identified the cause and provided a fix. Have you or anyone else heard about this problem, its cause and a fix yet? Firmware? Software?
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
    President:
  • 3,278 Answers
Recommended action 49 and 79 Errors, Turn off then on The product has experienced an internal embedded software error. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Posted on Jul 02, 2009
  • NinaE Jul 02, 2009
    Sorry ... remove "Turn off then on"
My advise, dont buy if you have return asap. The problem will not go away, I'm on my second printer.
Posted on Feb 15, 2010
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
HP Laserjet M2727nf Mfp error code 20
An error 20 means that there isn't enough memory to print what you want to print.
You will have to add more memory or simplify the print job.
Dec 09, 2011 | HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
I have an Hp m2727mfp with error code 79 and a few days before an error code 49, any idea what it could be?
Please update your firmware to the current version as this will usually fix these problems. Go to the HP website and search for M2727 software and downloads. Current revision is 20100902.
Feb 09, 2011 | HP Laserjet M2727nf Multifunction Printer
How to use scanner of the said printer HP LaserJet M2727nf
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01072069/c01072069.pdf.... check this link..this is the user manual of HP laserjet M2727nf MFP Printer
Nov 10, 2010 | HP Laserjet M2727nf Multifunction Printer
I have a laserjet m2727nf it gives an error 79 then switches itself off Laval
reset the printer memory .. turn the printer off, press and hold the down arrow and cancel while turning the printer back on
Jun 08, 2009 | HP Laserjet M2727nf Multifunction Printer
HP Laserjet M2727nf Multifunction Printer Logo
8,870 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
