Question about HP Computers & Internet
Just aquired an A3462A server mounted in a C2788A cabinet w/ 2 A3312A storage units. There's nowhere to attach a monitor. How can I solve this, I need to install a new operating system.
  • 339 Answers
The A3519A is the only graphics card available for this machine. Typically it's accessed more by serial connection or a remote connection like telnet.
It's been 10+ years since I've worked with one of these and the graphics card was a very unusual thing to see. IIRC, it wouldn't help you with loading an OS anyway.
The easiest thing to do is download a copy of Putty and connect a PC to the K460 with a serial cable and use it as a console.
Posted on Jul 12, 2009
Kitchen cabinet doors pop open
If the hinge is out of alignment, or simply worn out, replacement may be necessary. But, if the problem is the cabinet door (warped, or enlarged screw-mount holes) a new hinge will give you the same issue you have now. A small magnetic catch may resolve your issue with less expense and no alignment needed. It involves a small (1" square) metal plate with a single screw which you attach near the the lower corner that hangs open. The complimentary magnet attaches to the door frame of the cabinet housing (inside the cabinet). Available at even small hardware stores, the catches cost about a buck, install in a minute or 2, and will discretely solve the problem shown in your video.
May 05, 2013 | Hardware & Accessories
Tip
Smartvue S9R rack mounted servers are designed to be cost-effective HD...
Smartvue S9R rack mounted servers are designed to be cost-effective HD surveillance servers for larger, more demanding installations such as schools, casinos and warehouses with up to 100 cameras. S9R cloud servers also offer integrated Cloudvue service so you can remotely monitor one or thousands of servers from almost any web-browser, smartphone, or tablet. Built-in storage from 3TB up to 144TB available.
Smartvue Cloud Video Surveillance Cloud Surveillance CCTV
on Sep 05, 2014 | Home Security
Tip
Access to the NAS-T2 from Linux
Quick tip: when accessing the NAS-T2 from Linux, mount any NAS-T2 shares using smbfs, not cifs.
More detail: This tip presumes you're familiar with mounting filesystems in Linux and are trying to mount an NAS-T2 share in Linux. The older smbfs filesystem type for mounting Windows shares is deprecated in favor of the newer cifs filesystem type. However, the NAS-T2 is built on some older flavor of Windows and behaves very oddly when mounted as a cifs filesystem. Changing back to the older smbfs filesystem type solved all my problems.
on Jan 13, 2008 | Fastora 2 Bays Network Attach Storage...
Nas unreachable on network
Try connecting a USB mouse & keyboard DIRECTLY to the back of the server (plugging the monitor directly into it as well) then login directly instead of over the network. Repair may be possible if successful.
Dec 16, 2012 | LaCie Space 2 (301515EK) 1000 GB Network...
How do I mount this machine into an older cabinet where the machine drops into in horizontally for storage?
I don't think you would be able to - some sewing machine models came with a "Duplex" base which is different from the standard flat base with feet.
The duplex base is like a shallow dish with fixing points around it and allows the base portion to be bolted into a cabinet.
From the description of your cabinet I think you'd need some means to attach the bottom of the machine to the plate that swings to the horizontal plane.
I think someone would need to make a mounting up to suit your machine and somehow bolt this to the base/chassis of your machine.
Apr 20, 2011 | White Sewing 2037 Mechanical Sewing...
I'm removing a Maytag microwave over stove model #mmv4205aab. Would appreciate guidance. The only attachments I can see are two bolts which connect the unit to the cabinet above. I cannot see what...
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
Oct 09, 2017 | Maytag MMV4205 Microwave Oven
Problems connecting, stuck on aquiring network/renewing IP addres
i want to down load the mother board drivers and utilities c.d,how will down load
Sep 01, 2009 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Computers & Internet Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
