Why is the "E" lighted?
SOURCE: Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
SOURCE: canon p170-dh
How do I replace the ink roller? I installed a new one and only get black print instead of black and red. Both colors are on the new roller.
SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
SOURCE: Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
SOURCE: how do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
