Question about Cooktops
The automatic igniter continuously runs. How do I fix that? Model # JGP963BEJ1BB
    Novelist:
  • 222 Answers
Remove all the knob first,then get the vaccium to clean the bottom of the knobs control,coz some reason is dirty & ground.remove the plug b4 anything u do
Posted on Jul 04, 2009
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
Automatic igniters run continuously.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 03, 2010 | Smeg 23 in. SE64 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
Continuous clicking of gas stove starter
if it stiill click after u put to ignition mode if it starts automatically it could be the pub or manual will be the switch
Aug 10, 2009 | GE Cooktops
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Ignition stays constantly on, How to fix it or shut it off
its a gas cooktop it has to be plugged in somewhere op e the cabinet and unplug it. possible that the electrodes got wet and click from a false sense of continuity, after being unplugged overnight that will sometimes be enough. you also might have a bad start switch on one of hte burners causing the machine to click automatically. try unplugging over night first
Mar 11, 2008 | Maytag 30 in. CSG7000 Gas Cooktop
Clicking
In addition to polishing up the end of the igniter as mentioned above, remove the burner cap cover and and the round burner cap. As noted above, electrical contact or grounding is an important element in the spark igniter function. Any poor contact surface can cause the igniters to continue to spark after a burner lites. If everything seems in order, polish the underside of the aluminum burner cap and the top side of the aluminum burner base (where they come in contact with each other). This is part of the grounding circuit for the igniters. I used an "SOS" pad. In our case, these parts had tarnished with age. My wife was very happy when I fixed this one.
Dec 09, 2006 | Dacor Preference SGM365SS Gas Cooktop
Cooktops Logo
114 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
