Question about LG 50PX4DR 50 in. Plasma TV
Sounded like a pop of a electronic component and the picture died
The sound didn't stop but pulled the power plug just in case.
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. The pop noise may have been a capacitor or a inverter transformer. I can only guess at this point.
The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 02, 2009
Sony led tv picture black and won't turn on. I've unplugged it. Reset it. Only thing I can get is sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 08, 2016 | Sony Televison & Video
Today I went to turn on my car and it didn't crank
make sure the starter is tight and your battery cables are clean and tight if automatic try putting it in neutral if it starts you may have a bad neutral safety switch if it is a stick try push starting if it starts you may have a bad clutch switch also check for a starter relay if u have one try swaping with horn relay and see if it starts
Mar 25, 2012 | 1993 Ford Probe
I cleaned the outside unit of our Coleman Evcon central air conditioner today with a power washer. Now the fan is squalling, sometimes it sounds like morse code, sometimes it continues uninterupted for a...
Hopefully you didn't get the motor wet or any other electrical components. It sounds like you may have a motor with dry bushings. There may be an oil plug in each bell end of the motor. You can use thin weight oil , about 5 drops into each bushing should do it. If this doesn't work or it doesnt have oiling holes, the motor may have to be replaced Other wise, if you got the motor wet it may short out. In that case you would also have to change the motor
Jun 20, 2011 | Coleman Heating & Cooling
Fml 373b Polaroid ,no screen no sound . When I push the power button the light changes from red to blue . I unplugged and plugged about a week ago and when It wanted it sounded like a static noise and the...
You may have dying power supply problem, that will be the first palce to inspect, look foe any bad caps with domed tops, any burnt components and connections.
Service manuals: http://www.polaroidsupport.com
Please read my guide to get more understanding.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 10, 2011 | Polaroid FLM-323B Television
I own a sanyo "26
Tv now have it on green LED power on for good and tv flashes of pictures only for few min,than dies and have sound left only?Yes,take the tv aparts.U have all the tools and understanding basic electronic also can do basic soldering work too?Check the tv power supply board,that the board where the power a/c cord plug into it.Check the tv power supply board carefully for dead and dying components parts call capacitors.These dying and dead capacitors parts most likely all of the times,will bulges up or puffing up onto it tops.Changes all these dying and dead capacitors parts components,will solved this problems 70% of the times.If the tv power supply board it is good and no dying or dead capacitors component at all.Than the tv a long board that call the LCD inverter board it is dead.This LCD inverter long board are to helping the LCD screen panel to have a backlight to produced a picture.The tv long LCD inverter board have no parts for sale indivitually,al way have to buy a refurbish whole long LCD inverter board for the replacement.Also if you have no tools and soldering skills to fixed the power supply board by replacing capacitors component parts indivitually too.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a long LCD inverter board for the replacement.
May 28, 2011 | Sanyo DP26649 26 in. TV
My 42 inch flat screen was on and the all of sudden there was a big pop and the TV went blank. I could hear it clicking inside after this happened. Pulled the power plug to stop it. What caused the big...
It sounds like one of the Electrolytic Capacitors in the TV has gone, this can be caused by voltage fluctuations, Ambient Temperatures around the TV and sometimes they just fail for no apparent reason. If you are handy with some basic electronic tools you could open the back of the TV and you would possibly see the remains of the blown component as bits of paper like material around where a capacitor used to be.
Oct 25, 2010 | Samsung Televison & Video
I'm a student training to be a tech. Today I'm working on an Acer Aspire 5920 series and it's not taking power at all. No LEDs flash...nothing. While troubleshooting it I noticed an audible *popping*...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 16, 2010 | Acer Aspire 5920-6727 Notebook
I was riding and everything was working normal. then i lost about half my power and it sounded rough. the power would come back only momentarily but would disappear again. it was jerking when that...
You bike is missing on one cylinder. Since it comes and goes, it could be a spark plug or plug lead. This is the easiest solution, but there could also be a problem with the fuel injection system. Fit new plugs and test the plug leads. If the problem still exists, have the fuel injection system checked out.
Mar 21, 2010 | kawasaki Ninja 250R Motorcycles
I have a 2000 ford explorer 4.0 over head valve push rod 6 cylinder and i replased the heads both sides w new parts i also replased all gaskets and plugs and wires it ran great sounded good i drove it one...
have you checked your rods could have had a spring break or a rod bend or vavle bent could be head gasket or timing , just some things to look at
Sep 22, 2009 | 2000 Ford Explorer
Only a steady pulse comes out of my bull power
hello, it seems that you may have a bad ground on your amp? turn everything off(pull amp fuse at battery) and go to the amp ground and clean paint away to bare metal! secure ground tight and make sure the car battery is not low voltage! this may stop the pulse! the sound problem of no sound in speakers, if still there! make sure the speakers are not shorts or pinched to ground! this could damage the amp! hope this helps, good luck!
Jun 12, 2017 | Magnat Bull Power Reflex 300 Car Subwoofer
LG 50PX4DR 50 in. Plasma TV Logo
286 people viewed this question
Computer Repairing
Computer Repairing
