Question about SpeakerCraft MZC-88 Amplifier
Mcz88 Just wondering if anyone else has had any problems with any speakercraft items? We have had two units both a mcz-88 go out in 5-6 weeks. I am now hearing that their speakers might have a life time warranty but the other items might not and I can not find any warranty news on the non speaker items on their web site. I know the guy who put them in knows what he is doing but I think having a entire house of electronics not working after spending 30k+ twice now (problem not money) for more then a few hours in a month or two is more than I will put up with. Thank you to anyone who has some helpful opinions on this. Thanks PG
    President:
  • 1,114 Answers
If your installer is an authorized agent or dealer of speakercraft product, it has a 2 year warranty. What type of problems are you experiencing with the system? Do you have a single 8 zone system or are you daisy chaining two units? post a comment, and I can do some research for you. I am an integrator and it's quite possible to have system failures do to a number of causes relating to all sides of the product. Firmware, Software, Hardware, Programming, as well as power failures and wiring issues all can play a part in creating a real headache. I have had systems in the hundreds of thousands of dollars crash due to one conductor of one wire in a 30,000 + sf home. And it is very time consuming as well as aggrivating to all concerned. If I can help in any capacity, I will gladly do so. If your installer has your confidence, that's 80% of the battle.
Posted on Jul 02, 2009
    New Friend:
  • 30 Answers
I repair these.
http://calgary.kijiji.ca/c-buy-and-sell-electronics-Speaker-Craft-MZC-and-BB-Series-Amplifiers-Repair-Service-W0QQAdIdZ229607818
Posted on Feb 03, 2011
How do I hook up a microphone to a Speakercraft MZC-66?
This unit accepts LINE LEVEL audio signals only. You cannot attach a low level microphone directly to this unit. First, it doesn't have the correct inputs for a direct connection. However, you can use a microphone pre-amp that will accept the appropriate jack for the mic and it will provide a line level output for the Speakercraft. You would have to choose one of the inputs on the MZC such as CD, or source.
Sep 29, 2014 | Audio Players & Recorders
88 ranger 2.3L 2wd ext. cab have to start repeatedly and then jerks and stalls
Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units. Look for position sensor with intermittent fault. Check all wire connectors for loose or dirty.
Jul 28, 2013 | 1988 Ford Ranger
We have a SpeakerCraft MZC - 66 amp. This powered and operated ok on Friday and has just stopped working. There does not seem to be any power going to the unit. Any ideas?
is this generstion 1 or 2 on the mzc.. gen 2 has a fan built in on the top, if it is gen 1 Im sad to say every one I encountered with this problem needed to go back to speakercraft. the will sell a refurbished one at a discount
Apr 04, 2011 | SpeakerCraft MZC-66 Amplifier
All 6 zones buzz. mcz-66
Check to make sure no source or speaker cables cross power cables, and make sure power is clean by using a regulated surge protector.
Mar 14, 2011 | SpeakerCraft MZC-66 Amplifier
Hi can anyone help, i have a speakercraft mzc64 and need to use some premade cat5 patch leads to hook it up, i know the wiring is not standard,,,asny ideas please
What are you using the CAT5 for - speakers or Line Level?
Lamp cord would work (cheap) for the speakers and there's no reworking necessary. I wouldn't pass Line Level on CAT5, ever.
Feb 13, 2011 | SpeakerCraft MZC-64 Amplifier
One of my zones is not working and the control panel says "set zone" . There are no options available on the menu
hi,
you need the speaker-craft mcz programming tool to program the amplifier. you can program the system only through a computer. you have to program the mode 3.1. you also need a cable to connect the mode 3.1 to the computer ( Speaker craft DTP-6 Transfer Cable). through the computer u can set all the parameters of mode 3.1. you can download the software from speaker craft. install it it your computer. connect one end the DTP-6 transfer cable to the control port and the other end to your ps's serial port . run the soft ware and make wanted settings in all zones.
ok
Jan 29, 2011 | SpeakerCraft MZC-64 Amplifier
Speakercraft MZC-66 lost 4 channels
The fact that you are gettng noise out suggests that the problem is in the "front-end" of the amp. It sounds like the pre-amp section is smoked. What you are hearing is a little distortion that is getting through the pre-amp stage. This can be as simple as replacing a few cheap ICs. I don't know your exact model specifics, but this should be a straightforward repair. Where are you located?
Dan
Jul 21, 2010 | SpeakerCraft MZC-66 Amplifier
Speakercraft DBB12100 Amplifier, Circuit problem
Sounds like its a problem with over heating. open unit clean out all dust and dust bunnies wich compressed air. check that all fans are opperating. (fans on 6x100 amp units or thermal controled). If amp goes into protection prior to fans turning, there is your answer. the @ power supplies will have a green light on the output side. if the light in on power supply is good. or you can check that the output voltage is at 48Vdc on both units.
Sep 18, 2009 | SpeakerCraft DBB12100 12-Channel Amplifier
Another Speakercraftt failure
I repair these so they don't break anymore
Aug 28, 2009 | SpeakerCraft MZC-88 Amplifier
**** speakercraft!
Can you post the markings on the transistors themselves? I will look up what I can and try to get you a more common substitute. Post what eve information you can about the transistors and I'll see what I can find. The model and the output specs that are published for the unit would help too. Thanks, Dan
Jun 06, 2009 | SpeakerCraft BassX-10 Subwoofer
290 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Ronny Bennett Sr.
Ronny Bennett Sr.
Craig Butler
Craig Butler
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
