Question about Nintendo Pokemon Pearl Version for DS
My wep address got deleted and know i cant go on wifi how do i fix this
  • 24 Answers
You cant
Posted on Jul 18, 2009
I have router d link dir-524 i have change wep key then my internet have not connected what i do??
You should delete the old wifi history that was saved. From your device go to settings then wireless then delete or forget the wifi name... then search for wifi again and it will ask you now to enter the new WEP key. That should do it
Aug 31, 2013 | D-Link Air DWL 900AP (DWL-900AP) 802.11b...
Bit of a long story but Ill point form it: - Yesterday I noticed the Wifi was not working on the laptop. Thought it was just being stupid because it is an old laptop - Today my brothers XBox 360 cant...
Not logging into the router could be due to the IP address to log into it change after resetting the router. As for the wifi not working make sue that the deices are using the correct security settings. Remember older devices are not compatible with WPA and uses WEP.
Mar 28, 2011 | U.S. Robotics (USR8054) Router
How do you access your WEP key?
A WEP key is a security code used on some WiFi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders
So if you want to access your WEP key, I need to know what is the make and model no of your modem/router.
I need to know the IP address of the router, If you can pull up the router page using the default gateway address, go to >> wireless security>>Advance Settings >> There you could find submenu>>Authentication: WEP-OPEN>>There is a radio button to select >>Use custom encryption key>> inside the small box you can enter a ten digit telephone no. and make the save changes.
When ever you try to connet to the Internet using wifi, it will ask for the WEP key, you can enter your telephone no and get conneted to the internet
Aug 06, 2010 | Computers & Internet
I know nothing about computers and I need to find my wep key
The wep key is found on your WIFI router this s what keep your network private. you must access your router web page @ 192.168.1.0 or 192.168.0.1 or 192.168.1.1 you can find the correct address if you go to your start button on task bar and type command after pressing run and type ipconfig. The address is the same address for gateway. There are many different makers of routers so if you need more help list maker and model of your WIFI router for more help
Apr 25, 2010 | Nintendo DS Lite
I cant find my wep key
OPEN UR WIFI ADVISOR IT SHOULD BE NEXT TO UR CLOCK RUN IT AND CLIK ON ADD ANOTHER COMPUTER IT SHOULD GIVE U THE WEP AND NAME AND EVERYTHING U NEED. OR IF U DONT HAVE WIFI THAN THE PERSON U WERE GETTING IT FROM LEARNED HOW TO PROTECT THERE WIFI
Jul 04, 2009 | Nintendo DS Lite Console
Every time i try to set up wifi, it asks for a wep key.
The WEP key is a security key used by your wireless internet device (usually a router). Do you know who set up your wireless internet? If so they should be able to provide you with the WEP key.
Jun 24, 2009 | Nintendo Pokemon Diamond for DS
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
I cannot connect to wifi in my ipod touch
Change the router encryption or create an encryption as WEP using your Zyxel router.
The connection in your college is maybe unsecured or no security?
- Try also to check the settings of your router make that unsecured or configured a WEP encryption to the router.
- Turn off the MAC filtering of the router (Under advance settings)
- Disable the wifi-protected setup of the router (Under advance settings)
- Refresh the network list before reconnecting to the network.
Note: As we try WEP encryption to some of the router, the IPod can connect to the network.
Mar 08, 2009 | Zyxel P660HW-D1 Router
I need to switch to wep from wpa with 2wire and i cant find out how to i want my ds to work with my wifi
For most models, browse to the 2wire's GUI by typing gateway.2wire.net into the address bar.
1) Click on the homenetwork icon.
2) Click on wireless settings
3) Enter your system password
4) Left hand side under encryption change from WPA to WEP
5) Save.
Mar 02, 2009 | Gateway Wireless-B Router (wbr-100)
No wifi connection
connect by cable long enough to complete the setup
type this address in your browser
http:\\192.168.0.1
which should start the routers webinterface you can navigate thru the Wireless settings ,s et channels etc
and copy them to the pc that you are trying to connect,
WEP - wireless encryption protocol - a method of scrambling transmitted data for security - both ends of the link have to have the same code key or they wont talk to each other
Apr 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Nintendo Pokemon Pearl Version for DS Logo
118 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
