Question about Dell A940 All-In-One InkJet Printer
The printer is printing blank pages.
The printer was working fine after installing new cartridges, but is now printing blank pages. Even when I run a test page it is blank.
  • 71 Answers
STEP 1: Disconnect and Reconnect the Printer Power Supply
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
STEP 2: Run a nozzle clean on the Dell A940 inkjet printer.
To run a nozzle clean, perform the following steps:
1. Click the Start button, point to All Programs, point to Dell Printers, point to Dell AIO Printer A940, and then click Dell Printer Solution Center.
The Dell Printer Solution Center menu appears.
2. Click the Maintenance button.
The Maintenance window appears.
3. Click the Clean to fix horizontal streaks button.
4. Click the Print button.
The Nozzle Clean function prints a page.
5. Check the Nozzle Clean Printout to verify that it is free of defects and that all expected color bars exist on the page
STEP 3: Restore the printer settings to factory default
To restore the printer settings to factory default, perform the following steps:
1. Click the Start button, and then click Control Panel.
2. Click Printers and Other Hardware.
3. Click Printers and Faxes.
4. Right-click the Dell Printer icon, and then left-click Properties.
5. Click Printing Preferences.
6. Click to select Save Settings.
7. Under Restore, click Factory Settings (Defaults).
STEP 4: Clean the Contacts and Wick the Ink Cartridge
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
1. Ensure the printer is powered on.
2. Lift the scanner unit.
3. Open the cartridge latches and remove the cartridges from the carrier.
4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
Cleaning the Contacts
1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
2. Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible.
Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
4. Replace the cartridges in the carrier and close the scanner unit.
5. Print the document again.
6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Then run again STEP 2. If the printer still prints in blank pages, contact Dell Technical Support. They may need to replace the Ink Cartridges.
Posted on Jul 02, 2009
  • 15 Answers
SOURCE: Printer prints blank pages. Toner cartridges are
Problem with the printhead.
Get it replaced.
Posted on Oct 15, 2009
  • 10406 Answers
SOURCE: printing blank pages even in testing
Replace the "empty" ink cartridge(s).
Posted on Sep 13, 2009
SOURCE: won't print black!
I had same problem after refilling a cartridge, tried wiping head with damp cloth...kinda worked. I finally put my mouth over the refill hole and blew gently into it to create some pressure to unclog the cartridge. This worked very well for about a week. Then the problem recurred and I haven't had any luck getting black to print either.
Posted on Nov 07, 2007
  • 615 Answers
SOURCE: hp 1012 won't even print a test page. cartridge
first disconnect the unit from the computer then reset it on your computer go to control panel and add remove files and click on your printer file and select updat/repair but not remove and that will reload your software. reboot and connect your printer and start the test..that may over power the problem, if not try to reload just the driver
Posted on Nov 08, 2009
  • 30 Answers
SOURCE: My printer is printing blank pages. The test print
try switching both the printer and computer off & on. If it still doesn't print properly, try to copy a page rather than printing from the PC. That way you'll know if it is a printer problem or some communication error. When you say documents come out blank...are they colour documents or black only?
LC
www.inkbank.com.au
Posted on Nov 09, 2010
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
Hp inkjet 600 printer will print off emails
If the printer runs out of ink and is not change within 24 to 48 hours it will not print anything even if a new cartridge is even installed untill the printers contact where the ink cartridges fit into are cleaned with alcohol. The ink does dry up in there and causes this problem
Jul 16, 2010 | Epson Stylus Photo R2400 InkJet Printer
All blank pages when printing, new ink installed
You may not used the printer for a long time (1 week). The heads may be blocked. run the head cleaning utility.
Jan 08, 2010 | Epson Stylus C86 InkJet Printer
Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
May 27, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Will not print annymore
Thomas You need to get yourself a pint bottle or even two pints of ink solvent and a syringe and spray it into the print heads where you removed the ink cartridges and let it set about two hours. don't be conservative with the solvent. Please read the manual for your printer and after you run the printer through several cycles you will see the differences put the old cartridges in the trash and install new cartridges. this can be prevented if you run the printer through its self test and run clean print head cycles.
NOTE: put paper towels in the bottom of the printer so as to not make to big a mess
May 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
Dell A940 All-In-One InkJet Printer Logo
696 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
