Ac blowing hot air
Working that night come home from work hot as hell in the house whats up
    Sergeant:
    Champion:
  • 235 Answers
Make sure nothing is tripped and make sure the furnace does not have a burned out fuse.
Posted on Jul 02, 2009
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Heater only blows hot air intermittently.
Jeep Liberty heater not blowing hot air Questions & Answers ...
www.fixya.com > ... > heater not blowing hot air > Cars & Trucks > Jeep
Jeep Liberty cars & trucks heater not blowing hot air questions and answers. Ask your Jeep heater ... My 2005 Jeep Liberty will not blow heat through ... properly.
jeep liberty 2002 heat problem/hvac box issue - YouTube
? 3:12
https://www.youtube.com/watch?v=xf22fvcN1hU
May 28, 2013 - Uploaded by Joffre richer-desroches
Joffre richer-desroches. ... How To Install Replace Engine Coolant Thermostat and Housing 3.7L 2002 ...
Nov 01, 2015 | 2005 Jeep Liberty Sport
My gmc yukon 2000 slt rear ac blows hot air when i have ac . on and the front works fine .
I have a 2000 GMC Savana Van SLT with front and rear AC/Heat. My front would blow hot while the rear blew cold with AC on. It turned out to be low on Freon. It's hard to know if you have the right amount of freon installed because pressures vary depending on the ambient temperatures. So the best way is to remove all the freon then reinstall the recommended amount as listed on the evaporator housing near the firewall. This worked fine for me... works like new after installing the correct amount of freon.
Jul 01, 2014 | 2000 GMC Sierra
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
Air conditioning
It doesn't sound like you have low Freon, but you could. The clutch not engaging indicates low Freon. The fact that it works are all would indicate that it is not low on Freon. The only thing that would be wrong is the pressure switch is not working when it gets hot. The pressure switch works by shorting the float side connection to ground then there is enough pressure in the system.
Aug 03, 2012 | 2003 Dodge Caravan
A/c dosen't always come on the it blows hot air. worked on the way to work would not work on the way home
Check the AC line if it is gets cold when AC is on, if it doesnt that may mean there is a problem with the compressor or out of gas due to leakage. Also check if there is an electrical connection problem.
Good luck, summer with no AC really becomes annoying.
Jul 13, 2012 | 1995 Buick Riviera
AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
Jan 12, 2010 | 2001 Mercury Sable
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
