Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
Access Really I have a 60 GB Pininfarina Portable that has worked fine until today.  When I plug it in, the light doesn't come on unless I press the USB plug into the slot hard and hold it there.  As soon as I let go, the red light goes off.
  • 3 Answers
It sounds like you may have a problem with either your USB port or the cable that you are using.
Try plugging in another device into the USB port.  If that works without constant pressure, try using a different USB cable for your drive.
Posted on Nov 09, 2007
My SimpleTech 120GB drive has mysteriously become read only. Is there a remedy for this?
USB - unplug then plug back in. then right click open check properties make sure you set "security" to read & wite & modify or FULL ACCESS.
Feb 03, 2015 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I have a Simpletech pininfarina 120gb external hard drive that I used to back up my computer.
did you purchase the storage sync program youmight not be able to download that version again unless you pay for it
if you can or want another free backup utility
save this to a document then click on it to open and download second back up free edition
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2242_4-10405044&ontId=2242_4&lop=linktitle&ltype=dl_elite_gen&pid=10999341&mfgId=6272401&merId=6272401&ttag=lst-4&destUrl=http%3A%2F%2Fdownload.cnet.com%2FSecond-Backup-Free-Edition%2F3000-2242_4-10405044.html
hope this helps
Nov 12, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Hi! I have a 250GB Simpletech pininfarina. I stored my PC stuff on the drive, but would like to now store information from my MAC. What do I need to do to get this working with my MacBook Pro? Jeffrey
hi balkanhope
Save information on a separate hd and wait for folowing operations to be successfull : format your Pininfarina in FAT 32 . Copy data back to Pininfarina . Connect Pininfarina to Mac and proceed further on .
Best regards ,
fanaudi .
Aug 18, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
My Simpletech 500 gb external hard drive has been working fine for a long time, today it said something was corrupted and then the computer has not picked up on the drive, when you turn it on the blue...
Sorry, but that sounds pretty bad. Generally when a hard drive bricks, its done. However you can try taking it in somewhere like the Geek Squad at Best Buy, and have them try and recover all your stored data from it. Good Luck!
May 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I am not able tp acces files on my simpletech 120 GB as this drive is not recognized both on my laptop and desktop
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 09, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
XP won't recognize Simpletech Pininfarina 60 GB external hard dr
Make sure you are plugged into a USB2 port and not a low speed port.
You can Bing the device name and more than likely find the drivers at the origanial manf.
Try removing all other external devices before installing the new one.
Re-boot the unit with all disconnected.
After the until has setteled down, plug in your USB drive in the USB2 Port and see if the operating system see's the new installation.
If it is see correctly, then you can install your other devices.
Hope this helps you.
P.S. you may want to look at the jumper setting on the USB drive and set them to default.
Oct 01, 2009 | SimpleTech Pininfarina 60GB External USB...
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
Simpletech 500 GB Hard Drive not working
The red light is an indicator of drive failure. The fall it took, especially if the drive was on at the time, could easily cause the drive to break something internally so that it will not function. I found SimpleTech drives to fail pretty easily, even when you're not dropping them. That's been my experience, anyway.
Data recovery is a very expensive proposition. If the hard drive doesn't respond to the interface as normal, they have to be pulled apart and data extracted from the internal platters. This isn't something you can do without a full safe room (dust-free, wearing special suits and all) because any dust can ruin the platter. Since it's so involved, it's usually really, really expensive. Generally, most people don't bother when it reaches that point unless it's business files (like all of your financial data, for instance).
However, if it's something you really need that bad, DriveSavers is one of the best:
http://www.drivesaversdatarecovery.com/
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Opening SimpleTech 80 GB Pininfarina Portable HD Case
Screwdriver no. Knife blade possibly. Pry with the knife blade flat against the seam. Work s-l-o-w-l-y.
Nov 24, 2017 | SimpleTech Pininfarina 80GB External USB...
External hard drive failure
Try to use Computer Management, goto Start> Control Panel> Administrative Tools> Computer management> Disk Management. select volume or harddrive available where you want to open. If the harddrive not yet assigned a drive letter; please assign it and apply. Then right click and explore.
Hope this will be helpful, please rate my solution SOLVED!
Best regards,
Philip
Nov 20, 2007 | SmartDisk FireLite 60 GB Hard Drive
Computers & Internet Logo
77 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
