Bought this model 8/4; returned; lowes ordered me another. Same problem with each one. No audible sounds at all. Have followed instructions to the letter. any ideas. returning 2nd one to lowes tomorrow 8/27/14. Any ideas?
Thank you for your post, phyllislowe!
It could have been an internal issue within the control panels. It is unfortunate that you had two appliances with the same issue. Without having a professional to properly diagnose the problem there would not be a definite answer to why the problem occurred. I hope this helpful. -Matt
SOURCE: Whirlpool Microwave Model MH3184XP
This is most often caused by a bad magnetron "scrambling" the controller, a bad connection on the controller, or a controller failure. Try to use the "timer" function of the oven. Make it count down without cooking for about a minute. If it works, then it's more likely to be a bad magnetron. If it still fails, it's probably a problem on the controller. We repair these nationwide by mail for $39.95 in most cases. For more information see our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
SOURCE: i need mounting instructions for frigidaire model plmvz169gcb
You can
download Frigidaire owner's manuals and installation
instructions here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
SOURCE: Handle on Frigidaire Microwave broken.
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Good Evening Gary, thank you for your post!
From the information you have provided you need to replace the lightbulb inside of your Frigidaire microwave. I have researched your microwave and you are unable to disassemble your microwave in order to replace the lightbulb. In order to provide you with a proper resolution I would suggest seeking assistance from a professional technician for repairs. This will help you avoid unnecessary part purchases or personal injury. -Matt
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
