Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
How do I do a basic tuning for a poulan pro 295
By texashighdef on Jul 02, 2009
how do I do a basic tuning for a poulan pro 295? Just above the pull start are two access holes, one labeled "T", the other "L H". The saw is running pretty good, however I feel like it is not getting fast enough rpm's at full throttle. I remember watching a guy do a quick adjustment to the rpm's once and I think he was accessing the "L H" hole. Unfortunately I was not paying attention and did not ask questions, but he seemed to be working on the speed. Thanks, Ian
Best Solution
posted on Jul 04, 2009
Helpful)
drallim
Rank: Guru
Rating: 87%, 761 votes
H is the adjustment you need. If you can see a slot-head screw, you can adjust it--some are blanked off to prevent any adjustment by the user. Proper adjustment is: engine should 4-stroke at no-load (engine warmed up), but smooth out with light load (cutting wood). Make sure the air cleaner is not obstructed as well as the muffler is not plugged.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
mestmcg
Rank: Guru
Rating: 87%, 34 votes
The `T` screw is your throttle control,the `L` & `H` is low and high speed. The normal procedure is to turn these two screws in full and then unscrew one full turn each. You start the saw and adjust the `L` screw gradually either way until it runs, do the same with the `H` screw while reving the engine. On some carbs. this can be tricky and needs a lot of patience, so if you are happy with the low speed only adjust the high speed. Hope this helps. Stephen.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
runs until I start cutting something, then turns off.
Answer
I had water in my hydraulic fluid in my Komatsu D39P dozer. I opened the drain plug, drained the... (More)
Answer
stihl ht75 wont start. Its almost new!
Answer
unable to pull starter chord seems to be locked
Answer
I have a craftsman electric stapler model #68496 and I need to know how to load the staples.
Describe your Chain Saws problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Chain Saw Experts
Top Garden & Power Tool Repairmen
in Windham, ME
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
