Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Ligh that is under the glass to make a copy stuck. Would not go backward or forward. Error E 7.
    President:
  • Xerox Master
  • 1,447 Answers
It is the problem your copier laser unite or toner lebel yet drum life is short
instractin:
open cartridge, developer,drum unite clean that and wait afew manuites then assembling it and make a copy
Posted on Jul 02, 2009
WHAT DOES ERROR CODES F 5-02 AND E 7-11 MEAN
both deal with the scanner located under the big glass. F-5 is bright light that comes on when you make a copy or the reader located under the glass that see the original, the E7 deals with shading of the original again under the glass get a tech to check out.
Sep 18, 2015 | Sharp Fo 2080 Monochrome Laser
Why won't 2000 nissan maxima passenger seat go backward ?
try to look under the seat for coins that have fallen down and got stuck in the track. it happened to mine!
Apr 07, 2013 | 2002 Nissan Maxima
My saab 900 is stuck and wont go forwards or backwards but the gears aer moving help
1-clutch
2-broken axle or c/v joint
3- transmission failure
Mar 13, 2013 | 1999 Saab 9-5
Using oakley thump pro 512mb, once reset glasses comes on but unable to use any of the controls to change song forward or backward or even to change volume. this is after fully charging them. what could...
I'm having the same problem....also if you try and forward to the next song...it will repeat that same song 3 times. Its almost like the volume butons are stuck or something...they dont seem to depress the same 9you dont feel a click or anything)... weird.
Aug 14, 2010 | Oakley Thump MP3 Player
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
THE SCANNER IS LOCKED
Look under the scanner lamp, in the opening where your copys exit. On the bottom side of the scanner there is one and only one green item, It is about 2 inches long and a half inch wide. That is your scan latch that has been bumped into the locked position when your removing copies.
Turn the machine off, Push it all the way in, then pull it out toward yourself until you feel it snap into the forward position. Turn it back on and it will be fine.
To resolve that premanently. Do this. When you lift your document feeder, you will see the glass strip on the far left. TURN THE MACHINE OFF. Remove the 2 silver phillips screws on the ends of that glass strip. Lift that glass strip out. You will see the green latch . It will have 2 tabs sticking up that you can squeeze those tabs to release the latch. Remove the latch, and reinstall it backwards with the hooked side of the latch away from the lamp assembly. Make sure you have it latched completly toward the front of the machine, it will not happen again of you do that.
Jan 22, 2010 | Xerox WorkCentre M15i Laser Printer
My hp dekjet F380 all-in-one
Do not place any paper on the scanner and open the lid and press scan button and check if the light glows and moves forward and backward. If the light does not glow its a problem with scanner light.
Also try to uninstall and reinstall the printer drivers.
Else please refer the weblink given below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=us&lc=en&dlc=en&product=1128296
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
The moonroof on my 2002 lincoln towncar is stuck open. I can hear the motor when I push the open button, but the motor sounds dead when I try to push the button to close. Could it be jammed? Is there a...
Temporary Fix: unsnap off the access door in the overhead ceiling liner behind the sunroof opening;
Use a 4mm hexagon Allen wrench to wind it closed.
Sep 12, 2009 | 1999 Lincoln Town Car
Ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Jul 16, 2009 | Minolta EP1030/1030F CS/PRO Copier
Honda Harmony mower, self propelled hydrostatic, wheels lock up when pulled backward. Going forward no problem.
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Apr 25, 2009 | Garden
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
54 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
