When in spin cycle, water flows out of washer to the floor. The tub is off it's thingy
  • 58 Answers
First, I'm not really sure that any washer contains a part called a "thingy", so I might need a little better clarification on that part to know. Is this washer a top load washer or a front load washer? What is the model number of the unit? Those bits will help me help you.
Posted on Jul 02, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
My Whirlpool washer tub filled with water, did not spin, over flowed, and partially flooded my floor. The final spin cycle did remove the water out through the hose. How can it be fixed?
the pressure fill switch has become disengaged....remove screws holding control panel and raise it up,you will see a plastic tube has become disconnected and must be reattached to a component directly under load size selector switch,usually a rust or orangeish color,sometimes white
Mar 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Simpson Esprit 700 Top Loader washer will not pump the water out
You situation could be caused by various problems. The easiest would be to check that no hoses on the drain side are kinked or plugged. This includes the tub to pump hose or the pump itself. Sometimes socks and other items can get stuck in the tub hose. Sometimes objects left in pockets can seize or hinder the pump ejection. Its sounds like if the unit is spinning and water is not ejected the above solutions should be checked first.
Feb 14, 2010 | Washing Machines
When washer goes to spin cycle it doesnt drain water
Remove the hose from the drain and lower the hose to a floor drain or a large bucket. If water flows, there is a failure with the pump. If no water flows there is an obstruction, such as a sock lodged in the drain path from tub to pump. Either condition will require some disassembly to repair.
Jul 12, 2009 | Whirlpool Washing Machines
A used washer I am trying to hook up . . I have the drain hose going into the floor drain. The washer fills while at the same time draining. So it never really fills enough.
Washing machines need to be drained into a standpipe. This is a drain that is about 36" off the floor. The drain line on your washer will work fine if you have it installed in a standpipe.
by putting it down into a floor drain, you're not going to allow the machine to fill. The stand pipe will allow your machine to fill and still pump the water out during spin cycle.
Make sure there's a drain hose with a hook on the top.
k
Jul 06, 2009 | Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Maytag washer PAV2300 water over flow
I had the same problem and went out to a website for Maytag washers. That website advised that the problem could be mechanical or electrical. In my case, the problem was a clogged tube and it took only ten or fifteen minutes to fix.
0. Unplug the machine.
1. Open up the front of the washer. Along the left hand side is a long transparent tube. The tube connects to a wallet size container on the side and near the bottom of the tub.
2. Inspect the transparent tube. It may be clogged where the tube meets the wallet sided container.
Note: When the tub is full, it creates pressure in that wallet size compartment which sends air up that tube to a pressure switch located within the panel at the top of the washer. The pressure switch flips and tells the machine - stop filling the tub with water. My machine had a visible clog in the bottom of the tube that carries the air from the bottom of the tub up to the pressure switch.
3. Disconnect the tube and clean. I used a pipecleaner to get most of the mold out. To completely clear the tube, remove the top panel and disconnect the tube from the pressure switch in the top panel and blow air down the tube.
4. Reconnect, test - and you should be good to go. If not, your pressure switch may be dead.
Dec 05, 2007 | GE Profile WPSR3120WWW
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
