Question about Canon PowerShot S5 IS Digital Camera
Screen and viewfinder only shows black....no picture
The camera seems to be working fine except the screen and view finder are both black.....they will both display the menu and other information, but there is no picture....
  • Canon Master
  • 4,738 Answers
Are the pictures also coming out black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 02, 2009
Why is my viewfinder black when the camera is on and able to take pictures using the LCD screen?
some camera will inactive the electronic view finder if you shot through the lcd monitor, try to find out in the manual book about shooting trough view finder.
May 04, 2013 | Canon PowerShot SX40 HS--Black
I don't know how to use the lcd screen when taking pictures
Many cameras that have view finders do not support use of the LCD display to compose or frame a picture. This is generally to conserve battery life of the camera. Most of these cameras limit how long a picture is displayed on the screen to 10 or 15 seconds, immediately after taking for the very same reason.
The exception would be a camera that lacks a view finder - or has a menu item that allows the user to compose the picture on the LCD in addition to the viewfinder. Some manufacturers call this "live view". Check your camera manual to see if it is supported. If so, be sure to buy extra batteries!
I hope this helps & good luck!
Nov 27, 2011 | Canon Cameras
Purchased my S5 IS second hand (buyer beware!) and everything seems to work perfectly except the viewfinder is blurry. I can just make out the wording of the info around the edges but end up reverting to...
Pls. turn the little knob near the finder untill you get clear picture inside finder, previous owmer might have turn the knob for his eye sight good luck.
Nov 07, 2010 | Canon PowerShot S5 IS Digital Camera
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
My view finder is screen is black..... when I take a picture, it shows the pic taken then goes back to a blank screen... it happened at a concert... it was fine then it went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 24, 2010 | Canon PowerShot A510 Digital Camera
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Apr 19, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
All pictures taken are just Blackness
is there a view finder on this camera? often when there is a screen and a viewfinder there is a button to toggle between them, my sony camera has such a button although it is not a cybershot. i imagine the button says "dis" or "LCD" and just needs to be toggled. if the display were bad you would not be able to view pictures on it. display works must be configuration issue.
Jan 05, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Black LCD and Viewfinder
I have the similar problem as above...Canon 5D
When camera is turned on the viewfinder is black. All other functions appear to be working correctly. I can view pictures on the card. I take a picture and it views on the screen and the spec's come up on the botton of the view finder but the viewfinder is 90 black with a bit of blur. Is this the censor or a mirror...?
Is this fixable and at what approximate cost? Would it be cheaper to replace?
Jul 31, 2008 | Canon PowerShot S2 IS Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
394 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
