Question about Fisher and Paykel DD605SS Stainless Steel Dishwasher
Leaking F&P dishdrawer
My F&P bottom dishdrawer is leaving a pool of water on the floor. it takes 2-3 towels to clean it up. i don't think it is the seal because that was replaced 6 months ago. and i certainly don't overwork it. please help
  • 784 Answers
Have you take the lid seal out to inspect it.
1- If the Lid actuator is not working right, it will cause the the seal distorted.
2- You also have a problem with the Lid actuators.
3-There are 2 on the left and the right, one of them bad can cause your lid seal replaced 6 months ago.
4- Good news for you that they can be sold only a pair. When you have them replace both.
The part number is 528113
Posted on Jul 03, 2009
Fisher and Paykel twin dishdrawer
there is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Jan 02, 2017 | Fisher and Paykel Dishwashers
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishdrawers display F1 fault, what do I do?
The flood switch at the base of the dishwasher (under the bottom drawer) has triggered. This means water has collected at the base of the dishwasher housing. This can happen for many reasons, leaking drawer lid seal, broken drain hose, broken water inlet hose, etc.
You will need to find the source of the leak. Also incorrect detergent can cause foaming which triggers the flood switch.
Turn the mains power to dishwasher off and take the cable out of the socket. You will have to find a way to take the bottom drawer out. Usually it needs a plyer to pull out the plastic fasteners one on each side. Slowly take the front cover out and lift the drawer off the rail and bring it out.Make sure the controller or display panel do not fall out. Use masking tape to hold these in place. Leave it on the floor without tugging too much on the cable and hoses. Dry the base with towels and hair dryer. The flood switch is mounted on a circuit board located in the base.
Put everything back and conne power and try again.
Hoses need to be replaced if these are source. Also lid seal can be replaced if this is the cause.
Use recommended detergent. (no power balls) or tablets.
good luck.
Dec 15, 2012 | Fisher Paykel Fisher & Paykel DishDrawer...
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Leaking fisher & Paykel DS603 Dishdrawer
i think there is a hole in the grey sump underneath rotor motor, the motor is the grey blades u took out of sump. pull out drawer, take filter tray and rotor motor out of drawer, dry all of water out of drawer , then look underneath unit , pour a little water into drawer and see if it is leaking past motor windings . if it is then there is a hole in the sump. if it doesnt leak from there try looking at the little black drain hose. please turn off power b4 u work on dishwasher do not want any accidents . please reply 4 more help.please tell me what u find. good luck
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Fisher&paykel d603 dishwasher
Disconnet Dishwasher, Remove lower dishdraw, soak up excess water with a towel, use a hairdryer to dry water especially under grey plastic cover. Then check seal on either dishdraw and make sure they are not kinked or leaking as this has most likely caused the problem. Power up problem should be resolved. Don't leave dishdraw unattended till you validate problem definately fixed.
Sep 06, 2008 | Fisher and Paykel 23 in. DS603H W Built-in...
How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Mar 20, 2008 | Dishwashers
Open Questions:
Why does my Fisher and Paykel DD605SS stalls midway through wash cycle? I'm not sure if the following incidents are related but my Fisher and Paykel DD605ss now stalls part way through the wash cycle. A few nights ago I loaded the dishwasher hit timer and left it to run in the wee small hours. When I got up the next morning the circuit breaker had tripped on the circuit with the dishwasher. Once I reset the circuit breaker I started the dishwasher. I almost always run it on Normal (Eco) 154 minutes. It ran and then started beeping which I presumed was it finished. It continued to beep and was displaying an E4 error. After searching the E4 error I took the most popular solution and unplugged the machine and left it without power for about 10 minutes. After that plugged it back in and hit the start button again. It seemed to run well and when I walked into the kitchen late in the cycle it was displaying 28 minutes to go with a scrubbing brush flashing in the LCD. I left it alone and went about my life and returned to the kitchen about an hour later and it was still on 28 minutes to go. I hit pause and had a look, there was water and foam in the bottom of the draw. I took the wet plates out and hit the rinse option to see if it was a pump problem. The rinse option ran and the draw was almost empty. I then took the rack etc out of the raw and cleaned it all out. There was a little gunk but not much. I put a light load of dishes in the machine and ran it on the Normal wash mode. It started up and made all the right noises so I left it. I came back to the kitchen and it was stuck on 94 minutes with the flashing scrubbing brush. I paused it, took the dishes out and again ran the Rinse option which drained the draw. So my question is are the three events linked? Circuit breaker tripping, E4 error and random stoppages during the wash cycle?
Feb 27, 2017 | Fisher and Paykel DD605SS Stainless Steel...
See all Fisher and Paykel DD605SS Stainless Steel Questions
Fisher and Paykel DD605SS Stainless Steel Dishwasher Logo
280 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
