The notice pops up for 5 seconds all the time
SOURCE: Resolution Notifier pops up every 30-45 seconds
Do you have an NEC display?
If so, it is part of the display's programs. Use the buttons on your monitor to select the "menu" then scroll to find "Resolution Message/Notification/Error" and disable or off.
This should do it.
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
SOURCE: the model number on my monitor is tft19w80ps it's
Don't know about the 5- minute pop-up, but this is how you get it back to english:
