Question about Apple 22" Cinema Display Monitor
22" Apple Cinema Display doesn't power on
When I press the power button, a white light comes on and then goes off again in a couple of seconds. I'm using an Apple DVI to ADC adapter. Is the power adapter bad, or is it a monitor problem?
It's a model M8149 22" Apple Cinema Display.
    Guru:
  • 206 Answers
This may be an issue with the display detecting the wrong video format or is using an unsupported resolution for this Apple Cinema Display 22"
Procedure:
• Make sure your Mac is turned off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Mac to start up.
If that does not help here is additional support reference from Apple regarding its LCD displays:
Apple Support Link:
Power Light Flash Issues
Let me know if this helps!
Regards,
-Mactechtrainer
Posted on Jan 31, 2010
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
Lap top will not turn on
There are a couple of things you can try. First let's make sure the battery has power. On the battery there is a little white button next to some LED lights. Press the button if you get no LED lights (they should be green) you have no power, if you get one fast blinking LED you have no power. Plug in your power suuply and make sure the green/orange light comes on on the adapter right where it attaches to the laptop. If you need to you can try a different power adapter if you can find on available from a friend or a store. Assuming you have power we could try reseting the SMC. Press and hold the power button for 10 seconds to make sure the power on the laptop is off. Unplug the power cord and using a coin or key to turn the circular lock, remove the battery from the laptop. Next with the battery out and the power unplugged press and hold the power button for 5 seconds then release. Replace the battery and lock into place. Plug in the power cord. Wait 5 minutes and then try to power the laptop on with the power button again. Hopefully this helps.
Apr 09, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple M8149 22" LCD.
This will be a driver problem. Solutions can be found on the Apple Support website
Apr 06, 2011 | Apple 22" Cinema Display Monitor
After a couple of electrical power outages my Cinema 20" Apple monitor doesn't work. The power light (lower right) goes through cycles of off, dim, bright, etc. sort of as if it's flashing a Morse...
There are three "morse code" flashes that an Apple Cinema display can produce that are diagnostic:
Three short flashes (morse "s") means incompatible video format. Try resetting the parameter RAM when restarting to go to the default
Short-long-short (morse "r") means "wrong power adapter." I've seen some monitors that will not work with an adapter that others will and that give this signal. In some cases this can be fixed by insulating the power sensing pin on the display power cord.
Finally morse "u" (short-short-long) means a backlight problem.
May 19, 2017 | Apple Cinema 20" LCD Monitor
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Need Repair Manual for Apple Cinema Display M8149
here is a manual for the 17 in. apple studio http://www.devicemanuals.com/guide/Display%20and%20Video/Apple/Apple-Apple-Studio-Display-(17-inch-CRT)-User%27s-TVRBek9BPT.html
Jun 30, 2009 | Apple Studio 17" Flat Panel LCD Monitor
Open Questions:
Apple 22" Cinema Display Monitor Logo
1,571 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
