Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
Bow mounted #pd 55 prop won't turn
I bought a new foot control thinking that I needed one because it would only turn one way, get the new control, now it turns both ways but the prop won't run, Dealer says the board is bad. Whats your take on this?
Sid Soodsma
  • 3 Answers
SOURCE: Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
  • 199 Answers
SOURCE: bow mounted pd55 trolling moter, 5 yrs old.
put the old one back on and see it the engine runs if so it is in the connection to or from the cable
Posted on Jul 02, 2009
SOURCE: need a shematic of minn kota maxxum 55 lb bow
the pin that holds the handle up broke, Is this a big expense to fix?
Posted on Jan 21, 2010
SOURCE: steering works on the minn kota pd 55 but prop
I haved the same problem, any info yet?
Posted on Jun 05, 2010
  • 157 Answers
SOURCE: Have 12 V bow mount trolling motor that doesn't
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Posted on Sep 20, 2010
I have a 2006 Lowe 160 Stinger Aluminum boat. I am up grading from PD 40# to PD V2 55# which has a heavier lower unit ...Problem is this unit mounts closer to the front edge of my boat and after 6 years of...
Hey 217,
Get a sheet of 3/16" aluminum plate that is at least twice as wide as your trolling motor mount and at least 12" longer than the mount. Secure the plate to the current deck.. align the front edge flush.
You might want to radius the edges of the plate and secure it with rounded head sheet metal screws.. This will make the mount much stronger and last!!
Jul 06, 2017 | Minn Kota Powerdrive V2 Bow Mount Trolling...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
Hot plug connector
if everthing else is hooked up properly and the battery connections are tight i would suspect a loose connection in either the plug or the receptacle. anytime an electrical connection heats up it usually means there is a loose connection or too many amps running through it than what its designed for. remember trolling motors should not be run out of the water for more than 30 seconds as they use the water to cool the output shaft at the prop. good trolling.
May 30, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Can i convert my bow mounted mini kota 40 to a transom mount?
No you cannot. Due to the hard mounted foot controls, it has to stay a bow mount.
Oct 18, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Same problem
Hello!
If you have a 55SC motor, it is hand controlled, here's a schematic:
55SC if this is your motor, I suspect the switch is gone, part # 2064023
If you have a bow mount FOOT control, here's your schematic:
Max 55 if this is it, I would first point to the foot pedal and/or the pcb control board. Best leave this one to an Authorized Service Center, here's the link with the list:
ASC Service Centers
...I hope it's just a switch for your sake ;)
Mike
Sep 20, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
