Question about Music
Have a Behringer Europower pmp5000 and I am getting no signal from my Mon 1 output (unpowered) or from my main 2 / mono (powered) output. Have full control of the main 1 and the Mon 2 but nothing from the others. I'm not super technical but can manage some small repairs. Could this be fuse issues? How do I access them?
4 Suggested Answers
  • 5603 Answers
SOURCE: Behringer PMP5000. The Powered Output B dead
Make sure the three position slide switch is set correctly for the stereo usage, that is NOT the bridged OR the Mon mode.
MAKE SURE the pan pots are set to middle as they control the spit of the audio to the two channels.
This is a class "D" amplifier (switching) and there really isn't any fuse for a single channel.
MAKE SURE your speakon connections are good by swapping your speaker cables.
I repaired my unit and had to do that without schematics... Behringer will not give them out. Mine had a severe arc-over on one side power amp taking out about ten transistors and diodes and one swithcing regulator chip. Had to cut out the "cancer" of the burned board.
This unit uses a complementary output stage that is made up of one transistor on one side and a pair in parallel on the other. This drives the inductor/capacitor filter... I think the switching frequency is between 100KHz and 1 MHz as I recall. All those transistors were gonzo. It also fried the main power switching transistors in the power supply, several smaller transistors, diodes, and the switching regulator chip.
Also two 10 ohm power resistors were fried. They soft start this unit by charging the main caps via two resistors that limit the inrush current.
A small switching supply has to come up first before the main supply which sends the DC to the amp section.
Posted on Nov 23, 2009
  • 5603 Answers
SOURCE: My Behringer Europower Pmp5000 Powered Mixer blew
Probably the channel A went. If you are fortunate, the power supply is still OK. There are protection circuits for the speakers, however you MUST use speakers that are rated at over 400 Watts. If you use smaller ones, they can get blown. There is a weakness primarily on insulation for channel A and an arc between layers of a circuit board can wipe out several transistors and a zener diode and sometimes a metering resistor. Once this happens, have unit serviced before using it again as further damage can result.
ALSO PLEASE read my tip I posted on FIXYA regarding a grounding hazard when using Speakon to 1/4 inch speaker cables... essentially the barrel of the 1/4 inch jack of the A channel is the hot lead, NOT the tip for that channel.
Posted on Nov 27, 2010
  • 5603 Answers
SOURCE: Europower PMP5000, In the Front Panel there is a
Yes, you can use both the main1 and main2. They are independently driven and please note that they are PSUEDO balanced drives... that is the cold side of the balanced line is NOT driven as a complement, but is merely returned to signal ground by a 120 ohm resistor. This CAN cause hum problems or noise pickup depending on the connected equipment and ground loops. Best to run this into amps/speakers thaat have TRUE balanced inputs and also keep the power source the same for all devices.
Posted on Nov 02, 2011
Europower PMP5000, In the Front Panel there is a Main 1 & Main 2 output, can I connect both to 2 Amplifiers so I have four independent outputs or 2 Stereo outputs? Can I Use these two outputs + mon 1...
Nov 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
HOW DO I CONNECT 2 SPEAKERS TO THE MIXER
Unpowered (passive) speakers connect to the Speakon connectors on the back of the unit. Powered speakers or amplified ones connect to the mains output L/R connectors (1/4 inch) near the upper edge of the panel.
Oct 06, 2011 | Behringer Europower Pmp5000 Powered Mixer...
We have a Europower pmp5000. It has been pretty good for us, but during our last gig, during a song, the sound totally cut out. We finally got the sound back by sliding the main volumn control up &...
Very strange behavior. Knowing the electronics within the unit, I see no reason that moving the main volume could restore operation. i tend to think that is a coincidence. Possibility the vibration of moving the control caused it to operate again. Do read the tip about PMP mixers I posted on Fixya about the hazard of channel A output if you use Speakon to 1/4 inch cables or adapters. If this happens again, try headphones and see if the signal still comes through them. There is an electronic fuse that can kill output IF the output current gets too high, but for that one you have toturn power off for some time for it to reset. Since you did not turn power off per your posting, that possibility is ruled out. Normally the sliders will NOT fail midstream and would be restored with any slight movement.
Apr 29, 2011 | Behringer Europower Pmp5000 Powered Mixer...
How do i hook up my jbl-jrx112m monitors to my pmp6000 so i can control sound volume,i have sound but only main control not monitors
You have to make a choice... you can tie two main speakers to the "B" channel and the two monitor speakers to the "A" channel.
The speaker configuration slide switch is set to MON1/MONO. The main slider controls the volume of the mains and the MON1 slider controls the level of the monitors in conjuction with the rotary MON1 knobs for each channel.
Each output should not be loaded heavier than 4 ohms. This would be a max of two 8 ohm speakers for each output.
Dec 24, 2010 | Behringer Europower Pmp5000 Powered Mixer...
My pmp6000 wont work in mon1/ mono mode. I have one speskon channel going to two mains and the other to two monitors Can't get sound.
OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Dec 03, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
No output power
It is likely the amps have been blown. Take for repair as further use may cause further damage.
Test the mixer by plugging headphones into the main L and R outputs. Note you will hear only one side of the headphone being these are mono outputs. The level will be low, but will check that the rest of the mixer is working.
ALSO please read my tip on here regarding a hazard of speaker polarity.
Oct 10, 2010 | Behringer Europower Pmp5000 Powered Mixer...
We are having problems with a Behringer PMP5000 board. We have the switch setting on Mon1/Mono. We can get sound out of the monitor output, but the mono output is almost silent. Do you have suggestions...
It is NOT clear what configuration you have set up and what you consider the MONO output is, whether it is the power amp MONO side output or the line level MONO 1/4 inch jack on the top of the unit (this jack is NOT speaker output). If you can run normal stereo speakers using both sides of the power amp in the AB mode, the problems you are having is pilot error.
REMEMBER the main out 1/4 inch jacks are BALANCED TRS jacks... DO NOT put mono plugs into these.
A WARNING: If you use Speakon to 1/4 inch speaker cables, remember that the BARREL of side A is HOT, not the tip!!! You can fry the amp if you inadvertently ground that barrel someplace. (Side B has the barrel grounded) This information is NOT readily available in the manual and results in many a blown amp. They do this to implement the "Bridged" mode easily.
I have schematics and can unravel most any problem you are having.
Aug 20, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Aug 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
No sound to speakers
There are many things, including hardware failure to cause this.
Make sure that the PFL buttons are ALL up. The LED indicators on the right are shared with solo channel and main output.
REMEMBER that the MAIN 1/4 inch jacks are TRS balanced and plugging a mono cable into these OR st the other end plugging into a MONO will short out the balanced line drivers. Since this also goes to the power amp, that can ground out the signal to the amps. All the other 1/4 inch jacks are pseudo balanced and mono plugs will not cause a problem other than possible hum or noise levels.
Do you get anything out of the PHONES jack?
Note that the standby switch must be UP in the upper right corner... it kills the first 12 channels. ALso with two speakers make sure the MAIN slide switch is in the MAIN A MAIN B upper position.
Start with all your PAN controls at 12 o'clock.
I have repaired two of these units and a PMP3000. Great caution: NEVER pull or insert speaker cables while unit is on. Great damage can be done. IF the fuse blows do NOT replace it!!! Get serviced immediately as replacing the fuse will likely do more damage. The worst damaged one required replacing around a dozen transistors and other components.
The power amps in these have a habit of arcing out... NEVER store in a high humidity area!!!
Try a set of stereo headphones plugged into the L and R MAIN out 1/4 inch jack... If you have audio there your power amps have failed or the +/- 85 volt supply has smoked.
May 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Music Logo
104 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
