Question about Tomtom One XL GPS Receiver
My tomtom one xl will not picking up satellites and I got lost.
All I did to solve this was reset to factory defaults and it worked again.
I had same problem and connected to pc and downloaded updates - picked up 8 sats straight away!
Posted on Jul 12, 2009
I need to factory reset my tomtom xl 325se
settings/change preferences
last page press rest
will ask twice to confirm and it reboots to factory default
Mar 06, 2013 | Tomtom XL 325 SE GPS Receiver
How to regain my gps signal?
The problem can be fixed by resetting the tomtom one xl gps receiver. Tomtom one xl gps receiver is common with this problem, after resetting it, it is most likely it will happen again. So be ready to keep resetting over time.
It most like is as a result of bad strength to search and detect the satellite. So you have to adjust the antenna also to a area where it can pick signals easily. This is quite uneasy because the areas to locate the satellite varies in terms of the location you are.
Software update will not fix this problem as well as the quickgpsfix, so the bes solution is for you to keep resetting it.
Hope this info helped. Thank you for using fixya.
Jan 21, 2011 | Tomtom One XL GPS Receiver
Tom Tom 540 can't find satellite signal for past hour
Software update will not fix this problem as well as the quickgpsfix, so the bes solution is for you to keep resetting it. Hope this helped. Thank you for using fixya.
Jan 20, 2011 | Tomtom GPS
NO GPS SIGNAL
Dec 22, 2010 | Tomtom One XL GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Lost gps and then found 6 months later and cant remember password
To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on it will be back to it's factory settings.
May 11, 2009 | Tomtom ONE XL GPS
Tomtom not finding gps satellites
i had exactly the same problem, i dont really know how i solved it but first i thought it could be a memory problem slowing the gps signel so i reset the tom tom to factory settings then downloaded the updates from the tom tom home program of corce i lost all my destinations but i didnt want to do a back up just incase one of the updates had a virus or something so if u want to keep them i sugest u write them down first.and then i got a safty pin and pressed the reset button underneath where the memory card goes twice the second time i held it down for about 10 seconds then i looked for updates again from tom tom home. after that in tom tom home there is an option where u can operate your tom tom on your pc so i tryed that and i put in a destination on the pc and clicked on demo tour so i watched the route first it was a bit slow but started to speed up a little. after it had finished i un plugged the sat nav and went for a walk with it around the house soon as i went out side and set a destination it found 6 gps signels,make sure yhe battery is charged to at least half. well i hope anyone who follows my steps gets the same results, thought i lost 200 quid cos i have had it over two years and its only guarenteed for 12 months. well good luck.
Jan 07, 2009 | Tomtom One XL GPS Receiver
No GPS Signal in TomTom One XL all of a sudden
I suddenly lost the GPS signal today and could not get it back. All I got was the "No valid GPS signal". My solution was to tap on the GPS satellite bars when in the route map. this brought up the "Status summary page of the TOMTOM.
I then again tapped the satellite bar which brought up the "GPS Status" page. I then tapped the bar labeled "configure".
The radio button next to the option titled "Minutes (dm.m') was selected. I then moved the selection to "Degrees (d.d) and it started working.
I had just downloaded the GPS fix 5 days ago so it is not like this suddenly caused it to stop working.
This may not work for everyone but this is what it took to get mine working.
Cheers
Jul 09, 2008 | Tomtom One XL GPS Receiver
TomTom One GPS fault
I would send it back to tomtom again and tell them it is definatly not finding satellites. Hopefully they will find the fault this time. if you prefer not to send it to tomtom but have it checked somewhere else , then maybe you can search online with google as I know there are at least 3 places to have it looked at but I won't mention them here as its not a forum for advertising. There are several reasons why its not picking up sats but there are 3 most likely causes. A/ Contact with top antenna board has become broken / unplugged ~ tomtom one and one V2. - B/ Ribbon cable has become unplugged ~ tomtom Go - C/ software faulty or faulty sd card . ......... Most likely cause is faulty file on SD card .
Feb 06, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom One XL GPS Receiver Logo
631 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
