Question about Gateway M305CRV Notebook
Gateway m305cvr wireless engaged but internet wont respond
Gateway m305 wireless prompt all engaged and signal is excellt,
im currently useing it on my HP. But internet will prompt that it is not connected to wireless.Deleted ATT and dsl connects since I dont need them to Documents but cant open it, I restored systems to earlier, same thing.except AOl prompt says its damaged. Cant access troublrshooting or Administrator, Can I remove AOl for MSn or others, I cant access recycle bin either files post but wont open?
Driver wireless notebook
An internal wireless card lets you access the Internet and a home or corporate computer network without the hassle of using an Ethernet or other type of network connection.
The wireless card grabs the communication signal flowing throughout the air and processes the signal through your Gateway PC's Windows operating system so you can access websites, email and related Internet-based services.
But like other devices in your computer, you must turn on the internal wireless card in your Gateway PC before using it.
Turn on your computer, if it is off.
Press and hold the "Fn" key on your computer's keyboard.
Press the "F2" key in the upper row of keys on your keyboard.
The wireless Internet card's connection utility will start searching for a wireless signal.
Connecting to a Signal
Click "Start," "Connect To."
If your Gateway PC is running Windows 7, click on the Windows symbol on the taskbar. Click "Control Panel," "Network and Internet," "View network status and tasks."
Click on the wireless connection you want to connect to.
If using Windows 7, click on "Connect to a network," then click on the wireless connection you want to connect to.
Click "Connect." Enter the wireless connection's network password (SSID), if prompted. Click "Next."
Click "Connect Anyway," if prompted with a message about the connection not being secure.
Click "Close." Open your Gateway PC's Internet browser or email application to start using the Internet connection.
Networking Your Computer
http://support.gateway.com/s/manuals/mobile/8508773/8508773m.htm
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark!?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamationmark! or a red Xright click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
http://download.cnet.com/Gateway-Wireless-802-11g-PC-Card-Adapter/3000-2112_4-73884.html
http://download.cnet.com/Gateway-Wireless-802-11b-PC-Card-Adapter/3000-2112_4-68468.html
You only need to check BIOS if you are " unable to install the driver "
Make sure you Ethernet/internet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigateto integrated peripheralslook for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Nov 26, 2013 | Gateway Lt2802u Laptop/notebook
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
I have a TP-Link TL-WA730RE Wireless Range Extender. I set it up using the basic wizard on the cd and that's all fine. I can get great signal to the wireless network, but can't access the internet. When I...
Open a command prompt and type:
Ipconfig /all
There will be a listing for gateway..
Do this with the new one turned on and then do it with it turned off.. I'm thinking it will show two different numbers.. They should be the same .. You can manually change the default gateway to the one that works.. But sounds like the range extender isn't set up properly. May need to do some manual config.
Sep 03, 2017 | TP-LINK TPLink (TLWA730RE) Wireless Router
I have a Linksys wireless wrt54g router. Service provider is cable and lost signal for a couple days. Had to reset modem & router and everything worked fine for 3 days. On the 4th day, 2 out of 3...
Hi, the gateway is your cable modem, so if that 3rd laptop can't find the gateway, it can't make its way out onto the Internet. Do you know if you're using DHCP (to automatically assign IP addresses to your computers)? If you're not sure, you probably are, and all you'd need to do to fix the problem is to open a command prompt on that laptop with the problem (in Windows XP, go to Start > All Programs > Accessories > Command Prompt; in Windows Vista or 7 you can just type "command prompt" into the search bar) and at the command line, type "ipconfig /release" and then, once the command completes (which might take a minute) type "ipconfig /renew". This will force your laptop to re-acquire its IP address, complete with subnet mask and default gateway address.
An alternate way to do it is to right click on your wireless icon in the system notification area of the taskbar and select Repair. It will accomplish the same thing as above, but Windows will do the legwork for you.
Hopefully that should fix your problem. If not, leave a comment and we'll go from there. Good luck!
Jan 17, 2011 | Linksys Wireless-G WRT54G Router
No wireless light, and no wireless signal detected
there is a possibilty that wirelss feature on ur router is not turned on as the wireless light is off.
U can open the gui(router page) of ur router by entering the default gateway on the browser address bar. First of all u would need to connect ur comp using the cable to ur router so that it could be connected to internet.
Go to command prompt and type ipconfig and press enter and it will give u the ip and default gateway of ur router.
U can type the same default gateway in the address bar of internet exploere and hit enter and it shud bring the router page.
Once u r on the router page u can check the wireless settings on to that and can alter them.
Jun 07, 2010 | Belkin Wireless-N Wireless Router with...
Satellite M305-S4826 14.1" Laptop : my computer wont load . it says missing bootmgr pr...
You can try to Repair your Windows using the Windows installation CD (for Repair choose R when prompted). You can let the automatic repair to try and fix it, if that doesn't work upon restart reboot and start the Repair again, but this time select Command Prompt or Console and put in "bootrec /rebuildbcd" without the quotes.
May 18, 2010 | Toshiba Satellite M305-S4826 Laptop
Internal wifi can be enabled but wont find connections.My network adapter is updated to the max,so im thinking its a windows configuration problem.I tried using an external wifi usb adapter but it did not...
when was the last time you're connected to the internet using wireless???have you downloaded the latest driver for 802.11???was ur comp able to detect a network???
- if not try to uninstall and reinstall the driver for 802.11
- check the wireless switch then press Fn+F5
- try also to remove ur network if able to detect then manually add it
- if not detecting any networks try to check WLAN Autoconfig @ services.msc at command prompt or run(general tab - start up type should be auto and service status should started
- then first,second and subsequent failure should restart the service under recovery tab
- check ur ipaddress it should 192.168.1.12 something
Mar 28, 2010 | Gateway M320 XL Notebook
Gateway M305 Internet Connection
The Gateway m305 has 3 WiFi hardware options, 2 Broadcom and 1 ActionTec. I have found at times that the wireless adaptor will have its own control and configure software running and it will not allow windows to manage it. If this is so you can manage the connection with the manufactures software or find the option in network connections in the properties of the wireless adaptor to allow windows to manage it. Either way should allow you to connect but I prefer to use windows management. I hope this is of some help. Good Luck
Jul 21, 2009 | Computers & Internet
Gateway M305 cant get wireless connection
check the fn key and f keys for )))))) wireless first
if not, turn unit upsidown check the wireless card antennas ( two wires with gold cup like connections, push on to them)
also in device manager locate your wireless card see if there is yellow mark next to card
to see if driver is there
Jul 21, 2009 | Gateway M305CRV Notebook
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Gateway M305CRV Notebook Logo
184 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
