Question about Irons
Heat goes off and on even after unplugging and plugging back in.
  • 67 Answers
Sounds like the thermostat in it is faulty. If its under guarentee, then take it back to where you bought it, if not it will be cheeper to buy a new one. Wallmart, Comet etc. In the UK Argos do one for £7.00
Posted on Jul 02, 2009
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
Auto shut off how to turn back on?
The automatic shut off is a protective device to let the iron cool down when not in use. Normally, if you pick the iron up and sit it down on the board or fabric, the iron will "sense" the motion and click back on to the heating cycle. To turn the iron off, just move the dial to the lowest position, or OFF and or unplug it from the outlet. If left unattended for a while, and when picking it back up to iron, if it does not come back on then you may need to increase the heat setting, move the dial a little, till you see the power light come back on. This is a safety item, and a good one, given the hectic lifestyles we have now, and having busy lives. If we forget to shut the iron off, it does it for itself after a period of non-use. No more trips to the store or wherever and remembering "I forgot to unplug/turn-off the iron I was using". Still, it's best to unplug and or turn it off when not in use. I prefer unplugging, so that it does not be a "vampire device" drawing even little amounts of current when not in use. And it's safest when unplugged and cool.
Sep 26, 2009 | Irons
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
My toastmaster steamxtreme iron was left overnight plugged into the electrical outlet. I thought it had an auto-shut-off? Now it won't heat up. Any suggestions?
unplug your iron, turn the dial to off.. then plug it in and turn the dial back on. this will reset the auto-off
Aug 15, 2009 | Irons
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
Iron shut off; will not go back on
There is a thermal fuse in the iron which blows when overheated. This fuse has to be replaced.
You can probably find one on-line at radioshack.com -- match the temperature rating of the old fuse. It'll have to be crimped in -- if you solder it, the heat will blow it.
Apr 29, 2009 | Black & Decker AS100 Iron
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
"Standby" on Digital Screen
Leave It Out To Fully Dry Dont Plug In or You Mite Damage The Chip Board
Jul 11, 2008 | Black & Decker D2020 Iron
Irons Logo
43 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
