Question about Toshiba 62HMX84 62" Rear Projection HDTV
Visible bands moving up the TV
My TV is a 52HMX84 which is 52 inches but shares the same features as the 62 in TV. Starting a few months ago, I notice that some visible color bands are moving slowly up the TV at all times. I have tried all types of adjustments in temperature, color, brightness etc., but I can not remove them. This problem is present whether I am using HD cable, playing DVD or playing PS3 games.
Please help!
    Problem Solver:
  • 18 Answers
Re: Visible bands moving up the TV
The bands are caused by unsheilded power cables that are near the
set. sometimes your tv cable or antenae cable is near a power
source and it is picking up unsheilded EM signals. Remove all
power sources near your tv and tv cable.
Posted on Dec 31, 2007
0 characters
3 Points
No picture
your projection bulb needs replacement i think...if i got you clearly!
Aug 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Samsung plasma TV, half screen is blacked out
Well, as per my last posting, I thought I would share. The problem of the bottom half of my 42 inch Samsung Plasma blacked out - meant a trip to the local TV repair shop. I have to say, they were great. I took it in and they were able to fix it after replacing a part - had my TV back in about a week. Cost was approx. $300. This was well worth it, considering how much I had paid for this TV only a few years ago. I had the repair done last month and so far, it's been great. Sorry, but I can't remember the name of the part.
Aug 10, 2008 | Projection Televisions
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Projection Televisions
Color bands at the top of the screen - Sony KDF-50E2000
I have the same TV with the same problems. Sony has issued a recall for these tvs. Contact sony and will fix it for free or give you a discount on another tv.
Apr 02, 2008 | Sony KDF-50E2000 50" HDTV
Problem with Colors Seperating
can the remote move the clors in all 4 directions? If not the convergence ICs need to be replaced. Also check the resistors that power the ICs they are located right next to the ICs
Mar 19, 2008 | Philips 60PP9202 60" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good me at
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
94 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
