Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
Bow mounted pd55 trolling moter, 5 yrs old. thought that the foot control was bad because it would only turn one way. got a new foot control, now it will turn both ways but the prop won't run. Dealer says that my electric board is bad. What your take on this.
  • ssoodsma Jul 02, 2009
    I sent the old one in for repair & won't get it back for 10 days.If cable is bad can that be replaced? how much does it cost?
    Sid
    Sergeant:
  • 199 Answers
Put the old one back on and see it the engine runs if so it is in the connection to or from the cable
Posted on Jul 02, 2009
  • chrisbock Jul 03, 2009
    it all deprnds on the model from arround 35 to 75
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Can i convert my bow mounted mini kota 40 to a transom mount?
No you cannot. Due to the hard mounted foot controls, it has to stay a bow mount.
Oct 18, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
467 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
