Question about Microwave Ovens
It catches on fire, through the center turn table.
  • tealily Jul 02, 2009
    Gee, Thanks, GURU
    I was looking for recall info, But, Thanks anyway.
  • Rich Elliott
    Rich Elliott May 11, 2010
    discontinue use and consider purchase of new unit.
  • 58 Answers
NOTHING in a microwave should ever be on fire. Depending on the damged cause by even a small fire, the repair may be involved and costly. Inspect stirrer motor by removing bottom of microwave with power off. Note damage and replace stirrer motor and wiring harness as needed along with turn table drive block. Check to make sure all connections with all wires are sound with no exposed copper wires or shorts of any kind. Test always using a cup or bowl of water.
Posted on Jul 02, 2009
Microwave continues heating even when off
The microwave has a short. You need to replace it, there's no real fix for it. Keep it unplugged and dispose of it. It will eventually catch on fire, and this isn't an exaggeration.
Nov 28, 2013 | Microwave Ovens
What caused this to catch on fire?
its the grease that has got into it replace it and allways keep it clean
Dec 06, 2011 | Frigidaire Microwave Ovens
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
Door latch does not catch ,yet light goes on and turn table turns but does not heat. what part is needed and special tools?
Possibly door catch and/or door interlock switch may be damaged.
No special tools are required, maybe a torq 20 screwdriver.
Nov 04, 2010 | Smeg FME24X Microwave Oven
MICROWAVE TURNTABLE DOES NOT ROTATE WHEN IT IS TSWITCHED ON.
Make sure your plate is accurately centered onto the brown circle with wheels. And make sure your brown circle has all of it's wheels, and make sure that's centered into the middle piece. If all else fails, it's likely the microwave belt that turns the table has broke off or fell off. You might wanna check the bottom of it, you'll need a screw driver for that.
Also note: Microwaves can still cook food even if the table does not turn, older microwaves didn't have this feature. Good luck and please rate my answer
Oct 12, 2009 | Microwave Ovens
Roper microwave caught a paper towel on fire.
Why is this even a question?
Of course a paper towel can get hot enough to catch fire in a microwave. In addition, anything not specifically identified as microwave safe can melt, deform, crack, chip, spark, catch fire, explode, etc...
This is not a microwave problem.
Mar 01, 2018 | Microwave Ovens
Microwave turned on by itself
Have you tried unplugging it than reapplying power ? Sometimes a power up reset will clear the logic on the control card and yes.. if it continues to run ...you have a potential fire hazard...
Sep 22, 2008 | Magic Chef MCD990W Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
