Question about SAMTRON 95P 19" CRT Monitor
Samtron 95P CRT Monitor
I have been successfully using this monitor for some 7 years now as part of a Time system I bought. For some reason the display is periodically appearing double on the horizontal axis, this usually starts at the top and bottom of the screen and then spreads throughout the whole display. At other times the distortion starts in the central rows of the screen and spreads upwards and downwards.
As a result of this I have downloaded and installed the latest driver from Samsung which is stp95.icm which I am using on WinXP. This has not helped solve the problem. The only way to stop the distortion has either been to switch the monitor on and off, which sometimes clears the display, or otherwise to change the refresh rate. Using the 'Clear Moire' function seems to exacerbate the problem at the various refresh rates.
I am currently running the monitor in 800x600 mode with 32-bit colour quality. The available refresh rates are between 60 and 144Hz and I have this set at 100Hz. I am using a NVIDIA RIVA TNT2 Model 64/Model 64 Pro graphics card.
Any suggestions would be gratefully received!
Many thanks.
  • Blurred Nov 09, 2007
    Erm...thanks for the response, but I don't know what that means. Is it possible to fix the capacitors? Is this a hardware problem with the monitor or something to do with the graphics card?
    Many thanks.
This caused by one or more capacitors on the horizontal circuit
Posted on Nov 09, 2007
  • d0tn3t
    d0tn3t Nov 09, 2007
    that is a hardware problem you need to open the monitor's cover and change the capicitors using soldring
    i suggest u to take it to any hardware repair specialist it is an easy job for him and won't coast u much...
Samtron 45bn power regular on/off
just replace the FBT FEA830 and check
Feb 11, 2009 | SAMTRON 55V 15" CRT Monitor
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Hook my moniter to my cctv system.....
YOU need a CCTV monitor...problem solved. Yes it will cost you money.
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 95P 19" CRT Monitor Logo
121 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
