Question about Metra 2002 Kia Sedona
Driver's side door won't open
I have a 2002 Kia Sedona and the driver's side door will not open from the inside or outside.  I have the inside panel off and I have yet to find the problem.
  • ballengers Jul 25, 2009
    The lock was completely destroyed. The mechanic had to drill through the frame to get to the problem and then replace the striker and the latch. It was a $250 problem that was not likely to be fixed by an amateur.
I just had the same problem on my 03 sedona(driver's door), a gentle pry popped the door open and I noticed that the 3 screws which hold the latch in place had come loose. I tightened them up and now I can open the door from the outside but not the inside.
Posted on Nov 15, 2009
What about a child lock button somewhere
Posted on Jul 24, 2009
How to fix driver side door handle
http://www.kia-forums.com/do-yourself/33723-sedona-front-interior-door-handle-replacement.html
Jul 08, 2014 | Vehicle Parts & Accessories
2007 Kia Sedona Automatic Driver Side Slidding Door troubleshoot guide
motor -fuse - motor drive . You will have to do preliminary checks to determine which it is.
Mar 19, 2014 | 2007 Kia Sedona LX Minivan
How do you remove door panel
take all handles (usualy star screw driver) door opener .elbow rest off first, gentely using a flat screw driver ease the panel away,these are usualy push in clips behind the upolstery be careful they are fragile.replacement is the reversal.
Oct 04, 2012 | 2002 Kia Sedona
My 2005 Kia Sedona passenger side front door will not open from the inside or outside. The door is closed, so I cannot access the panel. How do I get into the door to fix the apparent rod problem?
only one way i know off and thats to remove the front seats so the door panel can be taken off .its difficult i know but not insurmountable
Feb 12, 2011 | 2002 Kia Sedona
Driver door handler does not open door out side
mcdevito75 here, Sounds like the linkage on the inside of the door came off the handle, let a glass repair shop fix it.
Jun 16, 2010 | 2002 Saturn Sl
Drivers door will not open inside or outside and it is unlocked
I had that problem on a truck before. I had to pull the door pannel off. There is a linkage from the handle to the door latch. In my case it was broken. It may have came off on yours, or could be broken. Hope that can help you.
Apr 18, 2010 | 2002 Kia Sedona
Can not open the passenger side front door from the inside how to repair? Front pin of the handle came out from both sliding doors driver and passenger. how to repair?
problem with audi a6 quatro. I cant open front seat door from outside. what i have to do? should i take it to car- repair place, or i can fix it by myself?
Nov 04, 2009 | 2002 Kia Sedona
Kia sedona outside door handle replacement
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Pull back the weather seal and you'll be able to get to remove the bolts securing the outer handle on
Sep 01, 2009 | 2002 Kia Sedona
Metra 2002 Kia Sedona Logo
760 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
