Question about Kenmore Elite 45986 Front Load Washer
SUD light keeps flashing, water won't drain, won't turn on or off
Put a load of towels on to wash. Didn't hear any noise so assumed laundry was finished. Found SUD light flashing - cannot drain & spin, cannot rinse, cannot cancel, cannot even start over... machine will not do anything.
Wondering if it is a similar problem to another from June 30/09 where something was clogging the drain???
Thanks.
  • 15,935 Answers
The "SUDS" or "SUD" error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Obstructions in the drain pump and/or drain lines can attribute to air getting trapped in the drain pump and cause the error code. Double check all electrical connections to the drain pump and Central Control Unit (CCU). You will need to remove the top panel of the washer to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top panel in place. With the screws removed, slide the panel back, then off. The CCU is located directly behind the wash tub in the center of the washer. The Drain Pump connector will be the 6th connector (facing from the front L to R) in the center of the CCU.
3. Check the Pressure Switch to ensure it is good. The Pressure Switch is located to the right of the CCU as you are looking from the front. It is a small cylindrical shaped device with a connector plug and an air hose attached. The switch can be checked at several water levels by removing the plug and taking resistance readings at the connector pins. Readings are as follows:
(Pins are numbered R to L facing the from the REAR)
Pins 1 to 2 (SUDS Detect) – 0 ohms
Pins 3 to 4 (Overflow) – 0 ohms
Pins 4 to 5 (L1) – 0 ohms
Pins 4 to 6 (Empty) – 0 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Sud and then f35 code comes on where can I find a picture of where parts are located on washer
to get picture of where the parts are go to searspartsdirect.com and enter your exacy model#
Now then the suds means basically that the washer didn't fully drain and the F35 means that water wasn;t detected entering the washer at the start of a new load...if all the water disnt drain it wont fill so what the biggest problem when that happpens and it wont drain is a blockage in the drain pump filter..here is what you do to check the filter screen for blockage is;oldtech2332_34.jpgoldtech2332_35.jpgunscew a little,use towels/tupperware tubs to drain ALL water..once all water out unscwer completly and check for blockage
Aug 20, 2011 | Kenmore Elite HE5t Washer
I keep getting a SUD error, I have stopped the cycle and reset by unpluging the washer, it keeps showing the SUD error. What should I do?
This code indicates that an apparent sudsing condition is detected. It happens when a non-HE detergent is used. Run a cycle without detergent or allow the machine to fill then drain it to make sure suds are removed. The problem is in draining if the code still flashes even no detergent is used.
Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Kenmore machine is made by Whirlpool and therefore troubleshooting is basically the same. Click on link below for more detailed drain problem troubleshooting.
Drain Problem Troubleshooting on Whirlpool-made Front Load Washing Machines
Jul 20, 2011 | Kenmore Elite HE5t Washer
How do i access my dryer filter
On the front at the bottom left is a rectangular panel that you pop off. (I use 1/2 a wooden laundry clip so as not to scratch finish.) Have a bowl or a bucket handy and perhaps a towel or two. There is a tube clipped to the washer. Detach from washer and unplug it and let water drain into your bowl. When water stops flowing, plug and reattach. Then (with towels ready) turn the the pump filter counter-clockwise (the circle to the right of the tube) until it comes out. More water will drain in this process. Clean the filter of any foreign objects. Replace and turn clockwise until it won't turn any more.
Apr 17, 2011 | LG WM-3677HW Front Load Washer / Dryer
Will not drain. Washing towels-I got an error code. Towels are soaking wet. Now I am getting a SUD code. Waiting to see what happens after this. Now it comes up again with f 2 code. Why? Could I...
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed
you may want to check your drain catch by removing lower front panel and unscrew cap on front of pump, you may have a restriction or not using HE soap, before you remove cap from front of drain pump, attatch shop vac to washer drain hose and remove all water or you will have a big mess, if none of this works you may have to replace pump
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open
If you can drop down drain hose to floor level then drain into bucket this will allow you to open the door . Sounds like coin in the pump /remove the filter and clean check pump blades are free...Good luck
Apr 28, 2010 | Whirlpool GHW9100L Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
