Question about GE Profile Harmony DPGT750GC Gas Dryer
The dryer noise
The dryer starts and cycles however it is making a humming/scrapping noise could some please help with this matter
    Champion:
  • 205 Answers
It sounds like it is draging. Suggest re-leveling the machine if problem remains call a service professional
Posted on Jul 02, 2009
Humming noise coming from front of my chevy van 2500 whe i start it and turn
To sell junker the website is very helpful for who are selling junker.i suggest all my friends that this website was very usefull.some kind of key word was given below......................................................... junk my van, junk my truck, scrap my car, scrap my vehicle, scrap my truck, scrap my van, remove my van, remove my van, remove my vehicle, scrap truck, scrap vehicle removal, scrap car removal, vehicle, disposal, tow my scrap car, tow my scrap vehicle,
http://cashcashcars.com/
Feb 08, 2012 | Chevrolet Cars & Trucks
The dryer ran for two complete cycles. the third cycle the dryer would not start. When the timer was switched it made a humming noise.
That sounds pretty typical of a motor that has tight bearing and shutting off due to excessive heat being created at the motor because of the tight bearings on the motor. What will usually happen whena motor is very tight is that it will run a few minutes (or cycles) and get too hot and shutoff until it cools down and will start then shutoff agian once too hot.Along with it not starting because of the friction of the tight bearing the motor will make a humming noise and may or may not start.
GENE
Oct 17, 2011 | Roper Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
Dryer quit working, When I turn the timer to desired cycle and push start it makes a Humming noise but does not tumble?
The humming noise is more than likely your drive motor. Replace your drive motor.
Sep 14, 2009 | Maytag Dryers
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
MY WASHER MAKES A HUMMING NOISE 3/4 OF THE WAY THROUGH EVERY CYCLE
sounds like motor brushes worn
how old and how much use has it had?
Jan 20, 2008 | Indesit W 123 Front Load Washer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
Dryer will not start
If if "hums" like the motors is working you drive belt may have broken. If it makes no noise other than the click it could be a blown thermal fuse (there can be several) or a seized motor.
Jun 15, 2007 | Kenmore 64722 Electric Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
145 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
