Question about Bunn CWTF 15-3 Coffee Maker
Our Bunn CWTF15 three burner is over filling. What can we do to correct this problem?
    Scholar:
  • 86 Answers
There is a timer inside the front panel re-just the timer with an empty coffee pot right up to the top edge with water only.
if not successful let me know and I'll go further with your problem.my email address dickson@lau.com
God Bless have a nice day.
Dickson
Posted on Jul 02, 2009
My bunn cwtf15 won't put out hot water from tap, and won't brew hot enough water even after adjusting thermostat?
your thermal fuse has blown. it's in what is now brown tubing and is located in the top right rear of the machine. remove the top lid, remove the trough drain nut and trough to get to it. you can either bypass it with a jumper, or call (800) 352-BUNN (2866)
Jan 06, 2014 | Bunn CWTF15-TC
Bunn model cwf15 overflows
There are several reasons why it could overflow. Check to make sure you still have the spray head on the unit. If you do, the level might be set wrong. Reset the level and see if that corrects your problem.
Feb 11, 2013 | Bunn CWTF15-TC
Just installed a Bunn cwtf15-3 Brewer. The water in the tank does not heat. Rear switch is on and the ON/LOWER switch is turned on and water does fill the tank. Coffee container will fill when the start...
Remove the front panel and make sure the pressure stat is turned up to max and back it up 1/4 way. If you have done that already then remove the top and check the thermostat and the inline fuse.
Jan 18, 2011 | Bunn CWTF 15-3 Coffee Maker
I have cwtf15-aps older model. Device is wired and plummbed in. lights are working but i get no hot water. Has not been used for about 3 years.
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 12, 2010 | Bunn CWTF15-TC
Pot only filling half way
If pot used to fill all the way then check the filter if one is installed and the restrictor on the back of the tank, you can also run the deliming spring through the brew tube.
If the pot never filled all the way then remove the front panel and use the instructions to reprogram the brewer.
Sep 24, 2010 | Bunn CWTF15-TC
Our Bunn CW series three burner is over filling. How to correct the problem??
needs service tech to adjust.
(Do it yourselfers can adjust the black knob down from 2.5 to about 2 mins. Digital timers have instructions in back of the front panel. CAUTION!! There is high voltage present. Pull out the plug! Safer to just have it serviced.)
Feb 03, 2010 | Bunn CWTF 15-3 Coffee Maker
Bunn model CWTF15 brews coffee but coffee not hot enough
Check the setting on the thermostat behind the front panel, it might not be set correctly, turn it all the way high the back 1/4 turn.
Nov 05, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Not enough water to fill canister
You might have to descale the boiler on your bunn coffee brewer, If you have the patience I can walk you through it.
Mar 22, 2009 | Bunn CWTF15-TC
No coffee.....but hot water spiggot is OK.
yes there is clogged inside its either the hose or the keypad / connection of the control is corroded.
Mar 09, 2009 | Bunn CWTF15-TC
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Bunn CWTF 15-3 Coffee Maker Logo
214 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
