Question about Boating
25hp johnson outboard motor was completely rebuild with new plugs and wires ,rebuilt carberator, new fule pump, new points and condensers. motors starts up and runs failly good and runs and 3/4 speed ok. but when opened up to run at full speed stalls out, but if speed turnd down engin will still keep running. seems to stall out at trying to hit high end of speek.tanks and hoses all new.
  • josephandes Jul 02, 2009
    gas tank vent was open, motor does not stall out. can run motor at 3/4 speed without stalling. only stalls out when trying to run at full speed. is there a secondary ckt of some kind that kicks in when throttle is turned completely open at high end. carb was rebuilt kit new plugs and wires new fuel pump new hoses points and condensers replaced. new gas tank and ball hose replaced. runs ok until hitting high end.
  • thomas foster
    thomas foster May 11, 2010
    make sure your vent on your gas cap is open
    Sergeant:
  • 331 Answers
I would check if the fuel hoses are big enough diameter AND the fuel level in the carburettor is high enough...
Posted on Sep 25, 2017
  • 157 Answers
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
  • 157 Answers
SOURCE: motor on ly runs on high speed
Hello rhett700, you have crossed a wire connection on the switch or your reostat is shorted/bypassed. If need be contact 'www.minnkotamotors.com/index.asp' ask for ext#406 ask for Dave. Have your model & serial # on hand. He is a good guy. Merry Christmas.
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
SOURCE: Wiring diagram for Die Hard 28 lbs thrust trolling motor
model #217592860
Posted on Nov 09, 2009
muffteck
  • 202 Answers
SOURCE: wiring diagram for 1982 Mercury 6cyl outboard tilt
go to ebay and buy a manual
Posted on Mar 27, 2010
Needle valve in an outboard 1957 Johnson
No, check threads on needle and carb. Ensure they are not stripped or cross threaded.
Sep 04, 2017 | Boating
My dad has a 1973 Johnson 25hp outboard that has been sitting for the past 5-6 years. When I try to start it, it's really hard to pull with the plugs in, easy with plugs out.
The biggest problem is the internal bearings. On an outboard, they are all roller and/or ball bearings. If the pistons stick it is not as big a problem as rusty bearings. It sounds like you have some great compression. (hard to pull with the plugs in). I recommend you visit with a local dealer who is familiar with this older model. A little care in getting it restarted (carb, fuel pump, water pump impeller) can help resurrect the motor. Also if they know these motors the can assess the internals without disassembly. It may need a tear down but without knowing more it is hard to say. I live in south Florida.
Jul 26, 2015 | Evinrude / Johnson 135-150-175-200 HP...
I have a mercury 25hp motor with a # DA758339. I am looking for a power head
A pro over haul will cost around 2000,00 includes new water pump carb rebuild plugs hoses and ect
Feb 22, 2015 | Light Outboard Motor Boat Bass Fishing...
What year and model is my antique evinrude motor?
I have never seen anyone answer these questions.if you looking for a condenser they are all the same.eg a 1965 40hp condenser will fit a 1955 20hp
Oct 01, 2014 | Sierra International 18-5199 Marine...
Evinrude year serial number 3014-10340
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
Aug 20, 2014 | Sierra International 18-5199 Marine...
1968 evinrude starflite 100 hp no spark
Some of those had a battery ignition with a short cap and rotor, and some had a magneto which reached down into the bucket. Both had points and condenser like an old car. The cog belt location was critical. 2 teeth off and it would not fire. the key switch was wired diferently for each ignition system.
Jun 19, 2012 | Boating
I have a 1966 Johnson outboard and cannot get any spark even after replacing the coils, condensers, points and plugs? Do these new coils need to be pre-charged?
sounds like you are grounded somewhere unplug your kill wire see if u get fire if you have 2 kill wires uplug them not sure but i think this motor grounds the co could be a bad cd get out the fluke and a manuel or go CDI website these boys will tell you how to ck the cd free
Nov 09, 2011 | Boating
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 | Boating
Jun 30, 2009 | Sport & Outdoor - Others
Boating Logo
1,052 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
