Problem for Refrigerators
Generic problem for all Refrigerators
Freezer and Refrigirator not cooling
The freezer and refrigirator are not cold.
The refrigirator was unplugged for a week.
After plugging it back in, the temperature inside the freezer and refrigirator remains warm.
Evaporator: room temperature (to the touch)
Evaporator fan: running
Defrost Heater: room temperature (to the touch)
Condenser Fan: running
Cold Controls set to 3 (factory)
Fridge manufactured: 07-2005
What could be the problem? What to check for?
Same Problem
Apr 16, 2009
-   if the compressor is not running and I don't hear any clicking, what's the prognosis? thanks- gar
gar278 Dec 17, 2008
-   my minifridge is warm!!!!!!!!! its bad should I buy a new one or is there somthing to replace>-   Guest Mar 19, 2008
-   subzero 245, plugged back in, light is on, compressor is not running, nor clicking, was fine before, any ideas? thanks-
killearn243 Feb 26, 2008
-   I have a Kenmore side-by-side refrigerator (model # 106.5706.601). The freezer stop working properly as many of the contents are thawing, however they remain "cool" tempature wise. I opened up the back panel and the fan is still running and there is power to the compressor. I'm not sure the relay is working properly though. Additionally, the water dispenser is working but there is no new ice being made in the automatic dispenser. Can you assist me in troubleshooting?-
bwalk05 Jan 28, 2008
-   my Whirlpool side by side refri (GD25DIXHT02, 7/8 yrs old) stopped cooling today, both freezer and refrigirator. it sounds the compressor constantly started with running sound and ended with a click sound. please help!-
cyao
Best Solution
posted on Nov 09, 2007
Rank: Guru
Expert
Rating: 88%, 1003 votes
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Was this helpful?1 person thought this was helpful
Solution #2
posted on Jan 07, 2010
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem, All i hear is a clicking sound when i plug the fridge back in. Everything seems to be working but the fridge isn't getting cold and the freezer isn't getting cold enough.
Popular Solutions for Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator
1 Solution
Frigidaire FRT21H7AS Top Freezer Refrigerator
2 Solutions
Hotpoint HSS25GFP Side by Side Refrigerator
1 Solution
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest...
3 Solutions
Questions and Unsolved Problems for Refrigerators
would like to hear about others experience with GE Profile side-by-side refrigerator.
Posted. Thank You!
what is the best french door refirgerator with ice maker ?
Posted. Thank You!
This refrigerater is 10 yrs old and have never had any problems with it. Then 2 days ago it triped...
(More)
(More)
This refrigerater is 10 yrs old and have never had any problems with it. Then 2 days ago it triped the breaker, and when we turned it back on, it isn`t getting cold, just cool. Any help would be appricated.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
my refrigrator is making a ticking noise like a clock and is not working. The temperature is at 60f...
(More)
(More)
my refrigrator is making a ticking noise like a clock and is not working. The temperature is at 60f and is not cold.
Posted. Thank You!
problen of temperature of the freezer no desfrose the condenser get freezin but not activated the...
(More)
(More)
problen of temperature of the freezer no desfrose the condenser get freezin but not activated the defrost swich not power
Posted. Thank You!
7 Other Users Have The Same Problem - Continued
Comment by anw2005, posted on Dec 12, 2007
My mini-fridge just stopped working the other day. I just unplugged it, and the motor is warm, so it has been getting an electric current through it, but it is not cooling at all.
Comment by tericlark, posted on Nov 18, 2007
My Whirlpool side by side refridgerator with the ultra ease filtration system broke down this morning. It was fine yesterday, but I woke up to get a glass of ice water and all of the cubes had melted, with water all over the bottom of the freezer. Both sides are not cooling. We unplugged and let it sit for 5 minutes and replugged it in, but still nothing happened. We checked the back of the fridge and there is no sound from it at all. However, the lights on both sides work, I am confused.
