Question about Everex StepNote NC1500 Notebook
Can't listen the higt sonoristion - Everex StepNote NC1500 Notebook
Power failure and higt temp
Power Failure, is it dead? If so call a repair man. Make sure you check the fuse to the fridge, no power to the unit may be the problem too, the sides of most modern fridges get hot thats how they diperse the internal heat.
Nov 21, 2013 | Refrigerators
Low beans don't work som times.. higt beans don't work they only work if I pull back on the suich
it can only be 2 things
1: bad combo switch (light switches in steering cluster)
2: bad wiring.
this assumes the car does not have DRL.
day light running lights.
i simple tool called a voltmeter finds this fault easy.
do yo have one?
Sep 19, 2013 | 2004 Suzuki Forenza
I turned off the machine too soon and now the grinder is stuck.
put thr grinder scale to higt number and press to make coffee,then turn it back on position
Aug 25, 2013 | Saeco Vienna De Luxe Espresso Machine
Fix death wobble
Please see the dealer.
Apr 26, 2013 | Cars & Trucks
My engine light came up with the code P0068 AND P0108. Anyone knows what wrong with my 2004 Pacifica?
p0068 TPS sensor problem,p0108 maf or baro sensor higt resistance,usually one or other has voltage problem or its desconected,you should check for voltage, disconecting one firs tand after the other one.
Nov 24, 2009 | Chrysler Pacifica Cars & Trucks
MY AMPPLIFIER KEEPS BLOWING THE FUSES WHEN IT REACHES HIGH VOL. i HAVE IT BRIDGED WITH THREE 10" SPEAKERS.
LOOK THE SPEAKER AND IMPEDANCE WILL SAME TO OUTPUT OF AMPLIFIER OR LOOK FOR THE OTHER SPEAKER WHICH MORE IMPEDANCE,FOR EXAMPLE ,IF YOUR SPEAKER HAVE 4 OHM PUT THE SPEAKER IN SERIE FOR INCREASER THE IMPEDANCE,NEVER CHANGE THE FUSE FOR A TO HIGT.
Aug 10, 2008 | Car Audio & Video
Everex StepNote NC1500 Notebook Logo
16 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
