there are 2 causes why your camcorder is eating up the tapes; either the tape head is dirty or there is a mechanical fault inside your unit (something might be misaligned that causes the film to be sucked in).
try to clean the tape head of your unit by using a tape head cleaner, it is like the tapes that you use with the unit but instead of a film there is a cloth like material inside that is used to clean the tape heads to avoid the film sticking to it
if the issue still persists then you should contact your manufacturer and set up a repair for the unit
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution...
(More)
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution or megapixel
I had a Sony DCR-TRV460 Digital8 Camera stolen and I need to replace it to be able to play my many 8...
(More)
I had a Sony DCR-TRV460 Digital8 Camera stolen and I need to replace it to be able to play my many 8 mm.Hi-8 and Digital8 tapes. What do you suggest?
My JVC GR-D 72U camcorder doesn't record. It happened after sitting idle for about a year. I took it...
(More)
My JVC GR-D 72U camcorder doesn't record. It happened after sitting idle for about a year. I took it out to charge the battery. Then when I wanted to use it, it won't record.
how can i get my videos from my panasonic camcorder to my PC, since there is no memory card, only a...
(More)
how can i get my videos from my panasonic camcorder to my PC, since there is no memory card, only a video tape?
how do I take video tapes media from a sony handycam ccdtrv81 and load it into imovie to make a...
(More)
how do I take video tapes media from a sony handycam ccdtrv81 and load it into imovie to make a montage with my own old home movies?
