Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmoore dish washer is not draining. Model number 587.16169400
plnolte
  • 62 Answers
SOURCE: Will not drain
There maybe something stuck in the pump or the pump is bad. I have also seen obstuctions in the drain hoses comming from the pump causing it not to drain properly.
Posted on May 12, 2009
  • 84 Answers
SOURCE: kenmoore washer , model 2262210 serial cl4434210,
if this is a traditional top load washer, then your lid switch might be bad. Usually when this happens, your washer will start fine. Your put it for a normal wash, it does its thing, lets in water, and agitate and stuff, but when it goes to the spin cycle. it stays in that cycle and wont advance. Leaving you with a tub full of water. Like i said if its a traditional top load kenmore, the lid switch is the the gray looking part when you open your lid. when you open your lid, youll see two screws holding it. But you have to take the whole shell of the waher to get to it....take 2 screws on the back corners of the counsel, then flip the counsel up. Locate to metal clips and pop them put with screwdriver. unclip the lid switch connector located by the clear hose that runs down. then lift and pull the whole shell towards your and acess the switch from underneath. put back together how you took it apart.( MAKE SURE THE CLEAR HOSE THAT RUNS FROM THE TOP COUNSEL TO THE TUB DONT GET PINCHED BECAUSE YOUR WASHER WILL OVERFLOW WITH WATER) like i said if its a tradidonal top load kenmore....hope this helps
Posted on Aug 12, 2009
milten1
  • 1304 Answers
SOURCE: have figured out that the problem with my washer
check your top for the push tag for the switch
if your able to push it and have it work, make sure the dog on the lid that enges it is good
all toled about 30 mins of work if your unfamilair with the repair
2screws on the control panel roll it over
remove the dogs that hold the cabinet down,,,, they should be on the back wall and look like copper
unplug the lid switch
pull the cabinet forward
the lid sweitch is mounted underneat
ive include the link and picture to order it
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11020802990&productCategoryId=0153200&brandId=0582&modelName=AUTOMATIC-WASHER&diagramPageId=00001&componentDescription=TOP%20AND%20CABINET&documentId=P9060120&blt=06
Posted on Oct 23, 2009
  • 44 Answers
SOURCE: I have a kenmore dishwasher, model 587-1625.
check for a plugged air gap (on top of the sink)
Posted on Mar 16, 2010
  • 2468 Answers
SOURCE: whirlpool dish washer model number du895s will not
check the sump area,check valve at the hose on the bottom of the unit,then check the house drain piping for a blockage,also kinks or obstructions in the hoses
Posted on Jul 17, 2010
Managemylife com sears
Bought a new Whirlpool dish washer from Sears. Can I take the drain hose off the hanger and install to my sewer system. Does drain hose need to be elevated to operate properly?
Jan 01, 2014 | Computers & Internet
Drain pump for Kenmore Elite top loading washing mechine
This will not be in the owner's manual.
If you search inside the cavity of your washer, however, you will find the service manual taped to the wall in a plastic bag.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmoore model#417.4105200 dirt stains/ dirty water residue
this is a drain problem.inspect the water pump, motor coupler and the drain hose for kinks.
Dec 14, 2008 | Kenmore 44921 Front Load Washer
Water will not drain during spinning
look at the pump and make sure you have the arm in the slot or it will not switch over to drain the water out
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmoore 22442 Washer will not drain or spin
I'm having the same problem with mine. Did you replace the lid switch or timer?
Jun 11, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
101 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
