Question about Dishwashers
Whirlpool 940 Series Dishwasher, Model #: DU940QWDQ3 I have lights on the control panel but when I push the buttons, all I hear is a click a few seconds later. The click is coming from behind the control panel. Nothing else happens. Dishwasher is about 13 year old.
catriver
  • 878 Answers
SOURCE: Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Posted on Nov 05, 2006
aborcass
  • 2651 Answers
SOURCE: whirlpool dishwasher repetes cycles continiously
yes does sound like a "stuck"button within the membrane switch cause constant restarting and/or re-cycling. wire diagram and tech sheet are generally located under the lower acesss panel(unless previous repair ***** returned it). tried looking up the part couldnt find exact model match mine all ended in Q1,Q2, ** Q3, but parts from my models ranged from 110-165
Posted on Mar 10, 2008
SOURCE: Dishwasher not working
dishwasher dwd 3410 w,it runs normal to the end but doesnt drain the water
Posted on Apr 02, 2008
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
Replaced the control board in my whirlpool dishwasher model# WDT790SLYM1 and the push panel lights up but when I push the start button all lights go out and the dishwasher will not start.
Hello, We're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 14, 2017 | Whirlpool Dishwashers
I have a whirlpool Gold series dishwasher that when I push the start button on my lights go out
Hello Cindy, we're sorry to hear about your Dishwasher. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dishwasher. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Dishwashers
Whirlpool dishwasher quiet plus 940 series. When I press the normal button, the light comes on, I hear a click, but the thing won't start. Any ideas?
Sounds like the door interlocking system. Is the door closing properly? Is there anything in the way?
Dec 26, 2013 | Dishwashers
Whirlpool Dishwasher will not start
Contact appliance repairman,
sounds like either a control problem, or the is a problem with the solenoid that opens up to let water in the dishwasher at initial start.
Jul 09, 2013 | Dishwashers
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool quietwash plus 940 series dishwasher that has stopped working. It left water standing in the bottom of it. When I push the button to start it, it makes clicking sounds and acts like it...
Well, the manual I found online is not free, it will cost you $9.99. http://www.user-manuals.com/user-manual-WHIRLPOOL-DU940QWDB3.html
Because you hear a faint click, that means that your power is probably making it all the way to your control panel. There may be a weak solenoid or some other component that is not working properly. It is also possible that there could be a bad connection somewhere. Do you have any experience in working with appliances like this? If not you may want to seek the help of a professional to work on this in person.
May 17, 2009 | Dishwashers
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Whirlpool dishwasher repetes cycles continiously
Mar 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
536 people viewed this question
Top Dishwashers Experts
