I reformatted the drive and am trying to install windows, during boot i hit f10 for setup and i get a beep and a blue box appears asking for a power-on password
SOURCE: Blue screen when starting up
Resolving the blank screen issue Follow the instructions below in order to fix this issue: 1. Remove any CDs, DVDs or memory cards from the computer. 2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected. 3. Restart the PC. 4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears. 5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER. 6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER. The PC restarts. 7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps. 8. Select Safe Mode from the Windows Advanced Options Menu. 9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue. If the blank screen persists or it is not possible to enter Safe Mode perform a system recovery Perform system recovery by visiting the given link for the steps. http://tinyurl.com/2hsjug To let you know I got this information from one of the geeks from ***
SOURCE: bios password lock
It is my understing that Windows XP was asking for a password and you chenge the one in the BIOS
Now the BIOS is asking for the password that you put when you say you resetted.
Please enter the password that you put in the BIOS and let me know if you are going to get a different screen other then the blue square with the picture of a key.
Best regards
SOURCE: Unknown power-on password on hp dc5750 desktop
If your using XP you need to run safe mode(press f8 while booting) then choose safe mode >2 box while show 1 with administrator and the 1 you mentioned>choose administrator>it will open your pc>go to control panel>users account>change or remove the user then restart...pls. rate
SOURCE: HP505N. Kids messed with computer and it shut
pres f 9 to choice boot menu. Or go F 10>go bios for set boot piority>and F 10> yes enter.if not work please re install xp .and create partion again ,because your kids can be delete the partion file (ntldr/boot.ini).
