Question about Samsung RB215LASH
My frezer is not staying cold
I nticed the temp was low a few times this week but i thoght maby the door was left open now it keeps getting hotter I have a samsung the frige is on top model RB215LABP
  • 42 Answers
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Posted on Jul 02, 2009
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
How do i put water in my radiator?
you need to replace thermostat and radiator cap.look under hood around engine compartment.look for a radiator cap near radiator,add 50/50 antifreeze and water to coolant system to bring up boiling point.pure water will cause engine run hotter because water evaporate away,remove radiator pour coolant in the radiator until coolant stop dropping in the radiator now some vechicle pour coolant in the coolant overflow jug,pour coolant until coolant level stop dropping and the coolant level stay at cold full mark.start engie let idle few minutes, watch coolant level in radiator if coolant start dropping add more coolant, when coolant level stop dropping put radiator cap back on let engine idle until both top radaitor hose and bottom coolant hose get warm turn off engine wait until it get cool then take a large rag slightly open radiator just a litle at a time to keep from getting scaled.once radiator remove add more coolant if low,put radiator cap back on start the engine let it idle watch the temp gauge if temperature gauge going hot zone stop engine wait until cool then add more coolant,keep doing this until engine stop overheating going into hot zone and coolant level stop dropping,make the coolant overflow jug coolant level stay at full cold mark, dont let jug run empty if so air will get in the coolant system causing engine to overheat.
Jul 22, 2012 | 2000 Plymouth Breeze
2004 Jeep Grand Cherokee temp gauge high when heat is on
If your "check engine" light is turn on, I suggest scanned the PCM to know exactly what fault code is stored there. Additionally, could be some problem with the "temp sending unit".
Keep us updated.
Jan 23, 2012 | 2004 Jeep Grand Cherokee
1998 Saturn Wagon 2 For the last few months my car cooling system seems to be running hotter than normal per the dash gauge. For years and even the the summer the temp gauge would never get over 1/4. I...
I would do a sniff at the tail pipe to make sure you are not pumping coolant out the exhaust pipe.
sound more like a bad gasket than a bad water pump to me.
Jan 27, 2011 | Saturn SW2 Cars & Trucks
Does not get cold enough to freeze ice at times . if i put ice creme in the frezer it becomes very soft. if i put bags of ioce in the frezer they will stay hard.. this with the control all the way up.
your door is probably not sealing properly. close the door with a dollar bill between the closed door if it comes out easy . that is your problem. you need a new door seal
Aug 02, 2009 | Refrigerators
A/C air sometimes cold, sometimes not on VW Beetle 2001 Turbo
AC will not work with temps are cold even when it is turned on. The air is colder cause the temp is colder. The AC cycles in hot weather because the AC charge is low and needs recharging. You will know this if you open the hood run the AC and you will hear the clicking sound of the AC compressor magnetic clutch. You can recharge it easily buy buying a compatible can of refrigerant. I suggest buying the kit with the gage so you don't overcharge the system which will cause freeze ups
Jul 03, 2009 | 2001 Volkswagen Beetle
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Samsung RB215LASH Logo
420 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
