Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
EC 12 how do you read the dip stick
Bought used EC 12 where on the dip stick means full.
    Problem Solver:
  • 8 Answers
It is really close to the bottom of the stick.
Posted on Oct 07, 2011
  • 146 Answers
They usually have a slash on the stick.
Posted on Jul 05, 2009
Purchased the AWD 190 CC, the mower came with oil but I'm not sure how much oil to put in a new engine and I'm not sure when the oil is full because there is not a clear understanding of what FULL IS
https://www.jackssmallengines.com/diy/how-to-change-the-oil-on-a-husqvarna-walk-behind-mower/
use the dip stick to measure the oil level there will be a F on the dip stick to show where full is. Wipe the dip stick with a rag and then put back in to measure the oil. Not mentioned about the rag in link above !
You can do this with cars too !
Jan 30, 2018 | Garden
How many inches is oil dip stick for nissan altima 3.5 ltr V6
How you check your oil level properly on a Nissan 3.5 engine
? 1:15
https://www.youtube.com/watch?v=5uih27KiKMo
Mar 2, 2013 - Uploaded by FixyourNissan
When you have no dipstick tube you can incorrectly check youroil level. ... How you check your oil level ...Missing: inches ‎ltr
Oil Dip Stick Reading...Help! - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../92792-oil-dip-stick-reading-help....
Mar 28, 2003 - 14 posts - ‎12 authors
Okay, I have heard that the dip stick is a little wierd. ... I've had no problems checking the oil level in many cars over the years, but the alti really ... Oil Change, dipstick reads above high
May 26, 2012
4.5 or 5 quarts of oil?
Nov 4, 2009
2005 Altima 3.5 liter tranmission fluid change
Sep 1, 2008
Checking the engine oil - w/ warm or cold engine?
May 30, 2007
More results from www.nissanclub.com
Check Oil Level 2002-2006 Nissan Altima - CarCareKiosk
Dec 13, 2015 | Nissan Cars & Trucks
How do you take the Dip Stick off
the dip stick twists out, and sometimes are tight, or hard to turn. be sure and replace it as tight as you can, back presure in the crankcase will blow it out if it's not tight
Jul 13, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Oil does not register when running
Fill the sump to the full mark on the dip stick and ensure that you keep it topped up to keep it there. 1/4 on the dip stick is not enough if you want to keep the engine in one piece.. For example there will be around 4 pints in the sump to the full mark and you are running on 1 pint. That means that the oil is getting super hot and oil pressure is suffering.
Nov 17, 2013 | 1996 Ford Taurus
The transmission dip stick was missing on my 2004 GMC Envoy when I bought it. I bought a universal dip stick to replace. What is the correct length of the dip stick from top to bottom from the opening?
Do not use a universal dipstick, go to a dealer or to salvage yard to get the proper dipstick. Correct transmission fluid is important for the operation of the ******.
Jun 02, 2012 | 2004 GMC Envoy
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
I have an Hitachi EC-12 compressor and I need to know how to verify that the oil level is correct. There is a green plastic dip stick but there are no markings on it that I can see indicating where...
Pull the dipstick and notice the notch cut into both sides at bottom (push dipstick all the way in to check oil level). Fill to top of notch. Lowest safe oil level is bottom of notch. This unit does not hold much oil. Always use the compressor on level ground (tilted compressor could cause a lack of lubrication). Good luck
Jan 26, 2011 | Hitachi EC12 Portable Electric 2hp Air...
Have you ever heard of the engine oil reservoir being full and the dipstick reading empty? I just bought an old 1985 toyota pickup truck and it was fine until I had my oil changed. After driving for a...
When your car is low on oil, there is a sensor (sometimes called a switch, as well) that will light up an indicator inside the car to inform you of the low oil level. In some cases, checking the dipstick will show that there is actually oil present, which can be confusing and frustrating because it contradicts the sensor. If this happens to be the case, more than likely the oil pressure switch/sensor is malfunctioning and will need replacing.
Keep us updated.
Nov 15, 2010 | Toyota Pickup Cars & Trucks
Where do I put transmission oil in 88 toy camry
If its a Automatic i presume it is, Locate the Dip Stick for your Transmission.Once located pull the Dip Stick Out wipe it off ,And toward and on the Bottom of the Dip Stick you need to Read it. It will shopw a mark (FULL) and it may tell you to Check when its Hot.If so go on a Short Drive come Back Pull the Dip stick out and if its below the Full mark ,Just buy a Funnel to fit the Small Hole the Dip Stick was It and Add a Little at a Time until it Reaches the Full Mark.(DONT OVER FILL IT) and Check to Make sure you put the Right Type of Fluid in. Your Local Parts Store Should beable to Guide you to The Correct Fluid: From The WYOCWBOY
May 27, 2010 | 1988 Toyota Camry
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
335 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
