Question about Dewalt DW618 Router
Trend t11 or similar bottom bearing gets very hot
I have just replaced my old dw625 for a new trend t11 but noticed the bottom bearing and sorroundind casing etc. get very hot.
is this cheaper bearings or just a running in thing, or should i send it back
2 Suggested Answers
  • 86 Answers
SOURCE: how to open the case in order to replace the
This is a serious disassembly and re-assembly.
Not only do you need to remove the yellow plastic cover end, but also disassemble the collet end. Depending on which version 618 you have it may have screws on the collet end or just a large nut. Sometimes you can't see the screws because they are plugged or covered with wood dust. The bearing is press-fit on the shaft on at least one end and requires an arbor press and special pressing sleeve. So you can only get so far on one of the 618 models then you have to use the arbor press to finish disassembly. The outside of the bearing sits in a very very close fit bore in the aluminum housing, which often becomes very difficult to disassemble without heating the aluminum housing. One bearing (top) must be pressed off the shaft and the replacement bearing precisely positioned where the old one was, so you need to measure with an inside snap gage, a dial caliper tail or depth micrometer to assure proper re-positioning. If you don't get it right then the motor shroud will rub the housing and the shaft won't sit right in the lower bearing.
You also need to replace the brushes while you have it apart. Between the labor, brushes and bearings cost you are better off taking it to a DeWalt service center - but even so, the cost to replace the router would usually be less than the service cost if it is out of warranty! Be very careful to make sure if you or anyone does do this job that the replacement bearings are properly rated for high speed - otherwise you'll be doing the job again in a few months of use.
Posted on Mar 01, 2009
How to replace bearings
If you cannot work out how to pull it apart by looking at it, you are probably better to take it to a Dewalt repair centre and have then do the repair. They make good equipment so it is worth spending the money to have a professional do the repair.
Feb 25, 2016 | Dewalt Get the lower price on DW625...
How do I replace the bearing in the passenger side transfer case?
just a drive cv.... replace
if leaks or more things found wrong
remove transfer case from gearbox
take apart properly
new seals new parts
Apr 21, 2017 | Cars & Trucks
Fit new main bearings with out removing motor
Not easy to get away with the crank get hot and most of the time
get marked or hot spots replacing bearing maybe a short time fix
ive done it .take emery. Cloth and shine the crank up as much as you can .if bearing spun forget it replace crank .good luck
Feb 14, 2015 | Cars & Trucks
Looking for DeWalt DW625 router manual
Make a quich search on google. I found several links where you can download the manual.
Sep 27, 2014 | Dewalt DW625 3 Hp Vs Elect Plunge Router
AWOE9140 (859201315010) bearing
It is cheaper to buy new top load washer than replace bearing on old front load washers these days
Dec 09, 2013 | Washing Machines
PEDALS / HUB CREAKING
Probably needs to have the bottom bracket rebuilt, new bearings etc. You can get a whole new set but you need the crank tools, so it may be cheaper to have it done for you. Tools are not cheap and you do not use them very often unless you are in business.
Oct 05, 2010 | Cycling
My GSXR 750F has spat out the bearing behind the main drive sprocket chewing the corner off the bottom crankcase what should i do. Repair bottom or replace. How big a job is replacing the bottom casing? Im...
hi,if your no mechanic ,dont attempt it yourself ,it will be quite a big job,engine out etc,i have not had a lot of sucess in repairing bearing surfaces in alloy cases,you would probably be better off(and it will work out cheaper in the long run) to find a wrecked bike or a dead engine from a wrecker or similar and get another case,either way it will be relitively expensve...sorry..hope this helps..cheers
Mar 01, 2010 | 1985 Suzuki GSX-R 750 F
Kia Sportage front wheel noise and vibrating
Sounds like a problem I had. Turned out to be the vacumn valve that locks the hubs when in 4wd. The car was not in 4wd but the hubs were always locked causing the wheels to vibrate and chatter especially when turning.
May 19, 2009 | 2001 Kia Sportage
Washer is leaving grease all over my clothes
I have this problem on my front loading washer too, but only when washing white clothes. I have just read that perhaps the inlet hose is disintegrating from the hot water being too hot. The hose disintergration can cause black greasy stains on the clothes. I am going to check out the inlet hose when I get home. Hopefully this is the problem... I am sure a new inlet hose is a lot cheaper than a new transmission or new bearings. BTW, my washer in only 18 months old.
May 18, 2009 | Washing Machines
Fixing the Cup
Take the breadmaker to any decent machine shop and show them the problem bearing - these bearings are standard and they will be able to find the right type and size to fit. Actually replacing the bearing is usually pretty easy, although sometimes heat and/or cold etc may need to be applied to get the old one off or new one on. Get them to check there is not also a rubber seal or similar that needs replacing too, as often there will be. Definitely can be fixed if all else is working fine. A new bearing shouldn't be expensive, $5-$20 would be about right and probably it's at the cheaper end of that. If it turns out that the bearing is a special one that they cannot get hold of, see if you can post back with a picture and some measurements, and any writing that is on the side of the bearing itself - hopefully we can source one easily enough online. Hope this helps :)
Apr 03, 2007 | Welbilt ABM3500 Bread Maker
Dewalt DW618 Router Logo
114 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
