Question about Polaroid Televison & Video
Flm3232 screen went black but still sound - no picture on any input ::: turned off and unplugged for one hour turned back on fine for five minuted then same thing - now no picture no sound
  • 744 Answers
Hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 02, 2009
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
Hi. I have a Mitsubishi WS-65807 65" rear projection TV. Unfortunately, I'm getting no picture on any input. The sound works just fine. Checking for a diagnostic code, I get 12: no problems. Occasionally,...
look inside the front of the TV Pull the left and right speaker grills off, Then pull off the decorative plate in the middle. Now remove the access panel underneath.
Take a flashlight and look carefully at the 3 boards that you'll see on the bottom. Look for any clear viscous fluid on these boards. What I'm afraid you may see is that coolant from one of the CRT's has leaked onto one of these boards. If it has leaked on the right-most board, this TV is probably trashed. If it's on the center or left-most board, it may be able to be fixed, but you'll still have a leak in one of the tubes, and obviously that's not good.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Frozen screen
sounds like the digital main board
Jul 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Plasma tv
have 42in Magnavox plasma just over 1 yr old picture freezes
for about a minute still have sound then flashes off then comes back on does this about every ten minutes after the tv is on for
a while used to take hours before problem occured has always
done this
Jan 06, 2008 | Televison & Video
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
