75 feet using 12 gauge wire
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wires
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: how to make multiple runs for low voltage transformer
Yes, It will work fine splitting it into 2 runs connecting them together in the transformer. It will work better than running them all on one line. Sometimes running them all on one line the last light s dimmer than the first light. I was an electrician for 14 yrs. and I promise you it will work.
SOURCE: I have a 300 watt Malibu transformer to run 4 step
Take one cable to the x-former to the 4 sets, then Splice all the wires (5 in one nut and 5 in the other) together. Then connect the one set at the x-former. Don't worry too much about the 10 ft issue. It will work fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: boosting output power
When you place the transformer in series you will be affecting the voltage on the output, placing them in parallel with give you the same voltage, but will increase the amperage output. Both transformers MUST be Identical. A switch must be used on the line side to disconnect Both simultaneously, for safety reasons.
SOURCE: Malibu 300-Watt Low Voltage Transformer ML300RTW Not Functioning
My power went off at my house. After it came by on how do I reset the transformer to come on automatically?
