Question about Brother MFC 4600 Laser Printer
MFC 4600 It displays printer jam error.
  • dlonra1021 Nov 09, 2007
    I've cleaned it but still it displays printer jam.Need help on how to resolve this problem.
    Problem Solver:
  • 6 Answers
Some paper has torn or a part is broken, have a very good look for any loose bits of paper. Take the ink out if you need to. 90% chance you'll find a small bit of paper that's causing the rollers to resist and the printer to stop with the error.
Posted on Nov 09, 2007
I had a paper jam, got the paper out but it keeps saying paper jam.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Feb 24, 2011 | Brother MFC-465CN InkJet Printer
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
How do i reset a brother mfc 240c
To reset the MFC-240C, hold down the power button for 3 or 4 seconds. The lights on the display should go out and the printer should slowly turn itself off. Once it is off, hit the power button again to restart it.
If the power button does not work (as sometimes happens with paper jams or other error conditions) you can unplug the machine's power cord in order to reset it.
Oct 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
"Unable To Change" message. Tried all suggested fixes none work. Can you provide any additional help beyond the standard fixes. Nothing is jammed, turning it off for even days doesn't remove the error...
press menu then start bk copy then fourtimes arrow up. what error code does the machine display?
In case you have an error 50 you have to open the printer cover and to reinsert the encoder strip which is out of position into the ph. This occurs sometimes after a serious paper jam.
search error 50 for dcp 110, 115 or mfc 210 here. its the same procedure.
Dec 17, 2007 | Brother MFC-5840CN All-In-One InkJet...
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Paper jam
push menu then start mono (b/W) then 4x arrow-up button. maintenance should be displayed. What error code does the machine give to you?
Sep 11, 2007 | Brother MFC-410CN All-In-One InkJet...
Here is the link to the manual; and here is the link to the driver downloads that i came across, in case you need them; Hope this helps :)
May 18, 2007 | Brother MFC 4600 Laser Printer
Brother MFC 4600 Laser Printer Logo
56 people viewed this question
James Cagle
James Cagle
Jim Keysor
