Question about Kitchen Ranges
Converting FrigidaireStove Model FGF368GSB From LP To Natural Gas
Hi, I just bought a used stove which was converted from Natural to LP Gas, and I am attempting to convert it back. I've researched it and believe that I need to adjust the regulator, however, I am not 100% certain of where the regulator is. Please assist.
    President:
  • 744 Answers
Hi you will need to get in touch with your local appliance parts dealer and buy a Natural gas orafice spud..thats basically all you need change although some manufacturers orafices you either losen or tighten up the orifice...like i say contact a local appliance parts dealer for the part. Hope this helps..please feel free to comment again if you have any other questions or concerns.
Posted on Jul 02, 2009
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
Want to convert from natural gas to lp propane
A conversion usually consist of new burner(s)/nozzle(s)/orrifice(s) and either a new regulator/gas valve..
Some gas cook stoves or ranges come with the ability to run on either fuel and the spare nozzle or orrifice will be attached somewhere on the stove.. usually under the range top.. the gas valve may have a small lever that you simply move to the preferred fuel setting.. NAT or LP.
The appliance must have a rating plate that states it can be converted.. and if so..typically a conversion kit will be available or may have been included in the appliance package.
LP Gas runs at a higher pressure.. making a broad statement here.. converting from Natural to LP is more dangerous if the proper steps are not followed then converting from LP to Natural.. which typically just results in a weak flame.. regardless. it's still dangerous.
Many modern appliances will have a warning label stating it can only be used with a certain type of fuel. Heed the warning.
If your appliance did not ship with the alternate fuel kit or has a warning label.. do not attempt to convert it.. it will be much safer and cheaper to buy the proper appliance.
Best of luck.. and be careful
Mar 29, 2011 | Heating & Cooling
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting a stove from natural gas to lp
Crank down the orifices and flip the regular nut.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2009 | Kitchen Ranges
Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Dec 15, 2008 | Kitchen Ranges
Converting to natural gas
Problem solved! I found the instruction sheet. Thanks anyway.
Aug 19, 2008 | Amana ACS3350AS Gas Kitchen Range
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
139 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
