Question about Dewalt 18 Volt Compact Drill Kit
Got a broken drill chuck i cant get off (Dewalt)
  • 2,176 Answers
First remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
Posted on Jul 02, 2009
3 Suggested Answers
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
mark24354
  • 776 Answers
SOURCE: How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Posted on Mar 19, 2010
How do I remove chuck on a dewalt right angle drill dw960?
Open the jaws and look inside. You'll see a fastener. Some have Phillips head or an allen wrench. Use the proper tool to turn the fastener counter clockwise to remove the fastener. You may have to help the chuck off the spindle if it sticks.
Feb 24, 2015 | Dewalt Drills
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
Drill chuck
I think that if you open the chuck as wide as poss there is a screw up in the inside if the chuck thinkk its a slotted head screw undo this and chuck will come off
Jul 23, 2010 | Dewalt 18 Volt Compact Drill Kit
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Chuck wont come off dewalt cordless drill 18v xrp my chuck bolt insid of the chuck wont come out and i need to know if it is reverse thred or not
i cant say 100% sure for that drill but im betting its not.
it probably has red loctite on it which is very tough to break free. put some heat to it. then it will come easily
Mar 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I put a short bit into my dewalt impact driver and now i cant get the bit out
Switch to reverse and driver mode hold tight the chuck then run the drill just to jack it... be carefull the keyless chuck plastic that release is easy to lose its grip to the steel so be patient. goodluck!
Dec 12, 2009 | Dewalt Drills
How do you remove a key chuck from a dewalt drill
first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
Oct 01, 2009 | Dewalt Drills
Dewalt 18 Volt Compact Drill Kit Logo
1,062 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
