Question about Campbell Hausfeld Maxus 30 - Gallon Air Compressor / Honda Engine - EX8006
No cold air
The air conditioner is not blowing cold air...i think the air compressor belt is missing
  • 744 Answers
Hi..
The evaporator coils on the front of the air conditioner get very cold during normal operation of the air conditioner. As the warm moist air in the room comes in contact with the cold evaporator the moisture in the air condenses out of the air and attaches to the evaporator coil. As more and more moisture condenses the water begins to drip down into the base of the air conditioner where it is evaporated to the outside of the house.... so the problem might be in ur evaporator coil.. try replacing the coil if u are an expert or else with the help of technician try to fix it..
Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
Compressor
Condenser
Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
Compressor
Overload and/or relay
Thermostat (Open thermostat)
Burnt wiring
Bad selector switch
Capacitor..
Posted on Jul 02, 2009
My air conditioner is blowing warm air on the driver side and cold on the passenger side
see this steps and think with clearly and logically NOT feared. God bless you
checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
Jul 24, 2012 | 2007 GMC Sierra Classic
Air conditioner light inside truck comes on but blows only regular air.. not cold at all
It isn't blowing AC at all, just air. See if your compressor is turning with the belts when the system is engaged. Not just the pully but the compressor.
Jun 08, 2011 | 2006 Dodge Ram 3500 Truck
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
Apr 19, 2010 | Intertherm P3RA-030K Air Conditioner
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
My air conditioner blows but will not blow cold. I think it may be a belt. Could it be the compressor?
Although it could be any of the major parts (compressor, evaporator, etc.), something to evaluate is if the air that blows is hot (like from the heater). If so, the problem is the blender door actuator.
Aug 19, 2008 | 2004 Mitsubishi Endeavor
Air conditioner
If the fan blows cold air the compressor is already on.
Jul 18, 2008 | Heating & Cooling
Campbell Hausfeld Maxus 30 - Gallon  Air Compressor / Honda Engine - EX8006 Logo
106 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
