Question about Samsung Rant Cell Phone
Logo keeps flashing and won't take a charge.
When I try to charge my phone in the outlet or thruogh the usb on my computer it won't always take the charge. Although, a few times when I did connect it to the computer it would charge but it takes a while. Mostly the red light at the top of the phone that lets you know it's charging soesn't come on at all and the logo keeps flashing. I can't access anything in my phone because it is completely dead this time. If anyone has an answer to this problem please let me know and I will gladly pass it along to anyone else who is experiencing this.
  • 389 Answers
There might be a problem with the phone or USB cable that ur using for charging, you can have it checked by using another USB port on your PC, try using another cable as well if it did nto work the phone needs service.
Posted on Jul 02, 2009
Phone keeps flashing logo when turned on but won't come filly on what do I do other than remove battery?
honestly it sounds like your battery is dead and unable to hold a charge. If you plug in the phone to the usb charger, does it come on completely? if it does your next step is to buy a replacement battery
Mar 05, 2016 | Cell Phones
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
How to turn on my garmin 265w
your battery in your garmin does not have enough power to stay on. You have to charge through your car outlet or usb port on computer. Only other option is to replace battery if it doesnt charge from car outlet since you said wont connect to computer.
Jul 13, 2014 | Garmin nuvi GPS
Why my tablet turns on when charging?
My ASUS Windows 8RT tablet is what I am basing this on, but it does the same thing. It's actually pretty common for the device to remain ON (standby) while charging. If you look at the battery icon, does it show anything different than usual?
May 17, 2014 | ASUS MeMO Pad ME172V-A1-PK 7-Inch 16 GB...
My GPX ML648S MP3 player turned off while charging and won't turn back on. What do I do?
are you charging with your computer through the USB cord or did you get an adapter to charge via an outlet?
If charging with your computer, it could be a bad USB port, try the ports in the back of the tower if your using the front and vice versa.
Is the device responsive otherwise? Can you load music and the like while the device is connected? If not your USB Cord could be faulty and need to be replaced.
If you are using a laptop keep in mind that sometimes the amount of voltage required for this device does not always reach the USB ports. Try disengaging the laptop battery for an hour and then reconnecting it.
Mar 12, 2010 | GPX ML648B MP3 Player
My LG KP500 won't start up - It just keeps flashing the logo.
I had the same issue with my KP500's screen flashing the logo.
The best way to resolve this is take it back to where you brought it from. They will send it off (which they did with mine) for a software upgrade and within a week you will have it back with no more issues and at no cost to you.
There is no quick fix solution. If you mess with the phone it voids your warranty.
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Samsung P520 ARMANI Cellular Phone armani phone won t start
i got the phone of ebay its a copy from china ive only had a week and wen i go 2 charg it sum times it will and other times it wont but even wen i try and turn it on it comes on for 3 seconds then goes strait off
Oct 07, 2008 | Samsung P520 ARMANI Cellular Phone
Motorola A1200 Problem
Easy step by step solution!
Hey guys had the same, Try this solution before buying a new battery/charging cable (it might not be the problem):
I did these steps after playing around with it for awhile and am at the stage where my phone turns on fully and says "Battery Charging" when plugged into the charger. It is now charging normally again... Finally! (I had the flashing moto logo too when charger plugged in) I believe this problem occurs because the battery is completely drained and is unable to turn on to charge bcuz the phone needs to be on to be charged, happened to me because i left it in a jacket pocket and forgot about it for weeks. Anyways...
1. You need a USB data cable for it, it should have come with the phone, if not than any USB data cable that fits the phone's charging slot should work (charge cable for the ps3 controller will work or maybe a cable from a digital camera with the same end)
2. Connect the phone to your computer via the USB cable and a USB port that works. Make sure it's plugged in and leave it (even if nothing happens and the screen on the phone is still blank). Although the screen is black, the phone is still charging via your computer (it's just too low on battery to produce the light on the display screen to load up your phone).
3. This might take anywhere between 15 and 45 minutes so be patient and leave it plugged in, beats buying a battery of charger with your money for something that can be solved for free.
4. At some point your computer will make the usual processing noises signalling that it is finally recognizing the phone as a usb device and shortly after your ming's screen will turn on stating that the battery is charging. Success! One of two things will happen, if you have previously installed the ming's drivers to your pc it will just recognize the phone. If you are like me and do not have the drivers installed, you may choose to do so via the cd that came with the phone or just not do it at all.
5. If you want to just charge it via the computer then congrats, your job is done, just leave it plugged in and wait until it is fully charged. If you wish to switch to your regular outlet charger please proceed to step 6.
6. At this point drivers installed or not, either safely remove device from the computer or just unplugg it. Now return your phone to your usual outlet charger making sure its connected. When plugged in you'll notice the moto logo appear (no longer flashing). After about 5 seconds that logo will disappear. At this time flip open the phone. The usual turn on sequence will play out and it will now load up with the battery charging screen similar to the screen from when it was plugged into the computer. Congratulations your phone should be back to normal now.
NOTE: This charge will take longer than your normal charging time but that's just for this time since your battery is super low it will be back to normal after that. Also if this did not work for your phone then now is the time to see if the charger/phone/battery is the problem.
So I hope this helps you out and eases your state of panic. I hope I saved you guys some money with this solution and that your mings are up and running again. I know i was pretty content when the problem was fixed. Please reply with any comments, questions or concerns you may have. Enjoy your once again working mings.
Jan 24, 2008 | Motorola Mobility MING A1200
Flashing Screen
try plugging it in and charging it for 24 hours while it is off weather it's fully charged or not try that or try taking the battery out for a couple mins and then putting it back in
Oct 24, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Samsung Rant  Cell Phone Logo
353 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
