Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
A
Anonymous Posted on Aug 26, 2014
How do i change the time recorded on incoming calls
Thomas Stauber
Level 3:
Master:
  • Master 438 Answers
  • Posted on Aug 26, 2014
Thomas Stauber
Master
Level 3:
Master:
Answers
438
Questions
Helped
90696
Points
1054
Make sure your time is set on the phone first that is how it determines the recorded time.
Aastra voicemail
This Depends on your providers system . If yo go and retrieve your messages and hit 4 3 2 2 this will get you to nowhere you can record a message for incoming calls. If you want to change you message for when some calls you and you are on the phone you would do the same as above but hit 4 3 2 1. That is where you change your "on the phone message" never put a date in that one. Just record " hi I am on the phone at the moment please lease a message at the tone" Hope this helps
1:- In my nokia e50 cell letter are very small ,so very difficulty to read message. 2:- voice recording is only for one(1)minitues.3:- NO voice recorder in phone for recording of incomming or outgoing...
ok
u can increase your font size by going in sttings and change and to record all calls u need to put in a software called spycall u can get on google install that in mobile and start recording as much as u like.
Jun 21, 2009 • Nokia E50
1helpful
2answers
How can i record my incoming & out going call for sony ericssion w810i
While in a call take options then select record. It will soon start recording the call.
1helpful
Not recording
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only)
3) Press the OK soft key. You will hear a confirmation tone.
2answers
Record voice on incoming & outgoing calls
no application needed on call go to more then record
1helpful
2answers
1helpful
2answers
How to record incoming calls ?
right side of the phone, below camera button on the right side of the phone, i do it by mistake all the time. Real Player should play the file for you. Hope it helps
2answers
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
Setting the Record Time
(1 Minute, 4 Minutes, or Announce Only).
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
