Question about Intel Gigabyte GA-8S648FX-RZ Socket 478 for Pentium 4 processor 800MHz FSB DDR400 ATX Motherboard wi... (MB47GB48FXRZ)
Gigabyte Motherboard wont flash bios
Motherboard model GA-8S648FX
with bios type Pheonix Bios D686
7 x 9 pins on the bios chip
The Problem:
When i boot the system the post does not come up. Instead the following report shows on screen:
Award BootBlock BIOS v1.0
Scanning BIOS Image in Hard Drive...
Can not Find BIOS Image in Hard Drive or Diskette!
Trials:
1) I had removed all Hard-drives/CDRoms/Floopy-Drives/Network_Connections etc and tried booting from a WIN98 Prepared bootable USB memory stick using the BIOS flash files and the autoexec files prepared and given from the Gigabyte Support and drivers website. No result and cannot detect drives or files same error.
Request:
I would like to physically short the bios chip in an attempt at resetting it as ive heard that it will resolve my issue but i need instructions from someone who knows the layout of this chip and how to go about shorting the bios chip.
I really need to get past this so i can get back to my programming projects...
Regards Colin
  • reach_colin Jul 03, 2009
    I had tried this method of flashing the BIOS but it was not possible to access the boot up sequence even with the floppy. I was looking for an option where I can short circuit the chip especially with the use of a wire that can be connected to two pins on the chip. Identified as GND and +5V. If you have any information on how that is done with the Phoenix BIOS Chip 7x9 Pin then please tell me what pins to short circuit where possible. Thanks again for any assistance offered in this regard.
  • 144 Answers
Your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Posted on Jul 02, 2009
Gigabyte bios rom error beep code
http://www.gigabyte.com/products/product-page.aspx?pid=3013#dl new bio here
Dec 03, 2013 | Gigabyte GA-EP45-UD3R Motherboard
Flashed the wrong bios on GA-MA785GMT-UD2H board. Gigabyte told me to short out pins 4 and 7 on the M-bios chip to force the B-bios chip to reflash the M chip. Did this but the PC still won't reboot.
Try taking out the CMOS battery, it looks like a big watch battery. Leave it out for about 5 mins. and put it back in, This should clear CMOS and return it to factory settings. Hope this helps..
Feb 24, 2011 | Gigabyte GA-MA785GMT-UD2H (4719331827199)...
Your BIOS to your GA-8I848P-G Motherboard would be flashable to the BIOS chip on the Board it's self. Make sure you read Gigabytes BIOS flash instructions. If the board is up and running Windows, then Gigabyte has there LIVE BIOS update you can run from there website!
Good luck..
Thanks for visiting FixYa.com
Nov 11, 2010 | Gigabyte GA-8I848P-G Motherboard
Wont accept bios update that was sent from packard bell after total failure keeps asking for bios file. also clear cmos feature on board three pins one with white square which i assume is pin 1 but header...
Ga-8SIML is a generic gigabyte mobo and does not need a packard bell bios. you could goto the gigabyte site and get latest from there. If your PB displays a logo at the start then its likely that you will lose that logo as the generic bios will not know it was fitted to a PB machine but thats no hardship.
Be sure to check the board version. version 1.0 takes one type of bios ver 3.2 another and they wont load into the wrong versions of the board. F12 is the latest non beta. I just did two of these recently so i know F12 is ok.
suggest you visit gigabyte site anyway just to check how the bios should be blasted and which version supports which mobo model no..
Aug 13, 2010 | Gigabyte GA-8SIML Motherboard
Dear Friends i have used in gigabyte mother board model no:GA-G41M-ES2L the problem is how i update my bios now is currently used in old version 1.0 but i have to update my bios pls tell me and solve...
you need to flash the bios .
download the new bios from gigabyte website and follow their instructions on how to update bios. be very carefull when doing this because if done incorrectly it would render your motherboard useless permanently .
in my experience if your m/b is working its best not to update the bios only time i would update the bios would be if the new bios update has new features that i really needed . if not i would not really flash the bios .
Aug 02, 2010 | Gigabyte GA-G41M-ES2L Motherboard
I need the front panel pin layout for a Gigabyte 8S648FX-RZ motherboard. (that is the power switch, reset switch, LED etc.)
Open the link for your Gigabyte MB 8S648FX-l;
http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s648fx_rz(c)_c.pdf
This is your manual. Go to page 15. You can enlarge the image if needed.
You will need Adobe Reader to view the manual. If you need Adobe it is a free download;
http://www.adobe.com/products/reader/
To view the main link for the Gigabyte 8S648FX-RZ click below;
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1775
Case front panel wire colors can be confusing. Most cases use colored wires as their +positive. White is commonly used as the -ground wire. Except when connecting an internal speaker. Black colored wire is ground.
Cheers!
Mike
Oct 13, 2009 | Gigabyte GA-8S648FX-L Motherboard
GA-8s648fx scanning bios image in hard drive
update the bios of motherboard, it seems that the bios file is missing somewhere and now the computer bios is searcing for it ..(on Hard drive)
so reinstall or update the bios it will fix the prob. otherwise if u say that the bios is working ok, then go to the bios and turn them to their Defaults, and restart.
good luck
shafky
Jun 13, 2009 | Gigabyte GA-8S648FX Motherboard
Post problem
You could try a program like EZ-Flash to flash the bios without using a dos disk. Gigabyte should have some type of program on their website that would do the flashing without makeing a disk as most new computers do not have a floppy drive nor does Windows XP/Vista use dos. Hope this helps.
Dec 18, 2008 | Gigabyte GA-K8VT800 Motherboard
Help!!! How to restore bios ?
You can replace the old BIOS chip with a new one, but unfortunately you will have to find a place to buy it (i would try the manufacture).
 Also you can check this link for some more information.
Oct 23, 2007 | Gigabyte GA-8SR533P Motherboard
Computers & Internet Logo
1,355 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
